Left Blinker stopped working...
Old May 30, 2003 | 04:12 PM
Ivory90's Avatar
Ivory90
Default Left Blinker stopped working...
The left turn signal doesn't flash, it's just stays illumimated. I walked around the car and found no lights out that I could tell. This is on a 1990 L98.
Does anyone know the fix to get that turn signal working? The right turn indicator works.
Thanks,
Frank.
Old May 30, 2003 | 04:32 PM
vader86's Avatar
vader86
Default Re: Left Blinker stopped working... (Ivory90)
The green light in the dash stays on when you hit the turn signal? That means the amber bulb is going out or is out. Are you sure the signal in the bumper is flashing when you hit the signal lever?
The bulb is a 1257NA i believe, you just lift the hood and youll see the bulb sockets in the front bumper, you push a little button and twist it ccw and it pulls out.
Old May 30, 2003 | 04:38 PM
Ivory90's Avatar
Ivory90
Default Re: Left Blinker stopped working... (vader86)
Thanks Vader!
The dash indicator lights up, the side lights had juice (so I thought at least).
I'll take a whirl at that bulb...thanks for the heads up.
To Left Blinker stopped working...
