Temperatures
Old May 30, 2003 | 05:33 PM
Vette Head's Avatar
Vette Head
Default Temperatures
I just did a flush and fill, and oil/filter change. I've only had the car for about 2 weeks, so I'm not very familiar with what temperatures are considered normal range.
When I'm just driving (freeway or city) coolant temp is about 160 - 165, and oil temp is about 170. If I get on it, or when I get off the freeway, temps go up to about 190 - 200 (coolant), and oil runs about 183. Is this average or normal, or is she running hot? What are the ranges it should be in?
It's a '85 coupe, 4+3, 92K
Thanks all - I'm learning
Old May 30, 2003 | 05:41 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Temperatures (kirks518)
Those temps are perfectly normal, nothing to worry about there.
Old May 30, 2003 | 07:59 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Temperatures (Bob86ZZ4)
Actually, that's running pretty cool.
Old May 30, 2003 | 09:12 PM
40thRubyRed's Avatar
40thRubyRed
I have the same question for my '93. In traffic i run from 180-200 (depending on the day) and in dead stop parking lot traffic upto 210.
Been following this very close since i blew a rad hose on tuesday. At the time I also changed my stat, and did a flush.
Old May 30, 2003 | 09:27 PM
kittmaster's Avatar
kittmaster
very normal
Old May 31, 2003 | 05:08 AM
Vette Head's Avatar
Vette Head
Thanks for the info. I can sleep better now.
Old May 31, 2003 | 08:04 AM
SOVAIN1's Avatar
SOVAIN1
Default Re: Temperatures (Mr Mojo)
:iagree:
Old Jun 1, 2003 | 03:21 PM
C10 JDR's Avatar
C10 JDR
Rats! nearly every post I read makes me wonder if I have got that particular problem - sort of Corvette hypochondria I suppose. Anyway this time I'm worried about temperature. I am running the same kinds of temps as stated, but my oil temp is always 10 -20 degrees hotter than the water. Is that normal?
Old Jun 1, 2003 | 11:17 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Temperatures (britvette)
Perfectly normal for the oil to run a bit warmer than the coolant. Don't worry, be happy.
Old Jun 1, 2003 | 11:32 PM
Strick's Avatar
Strick
It's nice to hear someone with normal temps. I was starting to think mine was running abnormally low. water=185 oil=200
To Temperatures
