D-port heads #113
Old Jun 1, 2003 | 04:51 AM
Corvette0096's Avatar
Corvette0096
Default D-port heads #113
Just ran my best of 13.00 on a untouched D-port head. 1.8 60 foot time and that was on Pepboy tires. Now here is my question. This right on target for this head?
TIA
Rich
[Modified by corvette0096, 1:51 AM 6/1/2003]
Old Jun 1, 2003 | 09:16 AM
vader86's Avatar
vader86
Default Re: D-port heads #113 (corvette0096)
If the 350hp untouched thing is totally accurate, 13 sounds correct.
Old Jun 1, 2003 | 10:40 AM
J Z06's Avatar
J Z06
:lol: you KNEW this was coming, but what M P H was under that 13.00?
Old Jun 1, 2003 | 11:24 AM
Corvette0096
Default Re: D-port heads #113 (Jay D 90 383)
Best MPH was 105.
Old Jun 1, 2003 | 11:31 AM
Vic'89's Avatar
Vic'89
Me and 65Z01 have stock #113 heads.
I have gone high 12's while 65Z01 has gone 13.0's.
These heads are very strong for a stock head. With a serious port job, they can run easy 115+ mph.
Vic
Old Jun 1, 2003 | 12:04 PM
J Z06's Avatar
J Z06
105 eh?
sounds good! about 300 hp to the crank.
Old Jun 1, 2003 | 01:20 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What's your exhaust system and other mods?
Old Jun 1, 2003 | 01:39 PM
Corvette0096
Default Re: D-port heads #113 (65Z01)
Hooker 2149, Lpe219, Super ram, Flowmasters, Dana 44 3.07 gears. 2400 stall. Random tech cat. Svo #24. Screen removed form MAF, Open lid..
Next Mods are.Ported and Polished Pro topline heads, Drag radials and Skinies. And lots of tuning.
Old Jun 1, 2003 | 01:58 PM
vader86's Avatar
vader86
Oh so it hasnt been tuned for the 219?
Old Jun 1, 2003 | 02:11 PM
65Z01's Avatar
65Z01
You definitely have some 12s in there now.
Install an AFPR set to current fuel pressure and then tune it at the strip for best trap speed. I'm guessing around 50psi for the final setting.
Also a 160 deg stat & switch would be a nice "free" mod.
Why not just get those D-ports pocket ported & worked a little with some "nice" 2.00"/1.56" SS valves. As such they will flow air for over 400hp.
[Modified by 65Z01, 2:13 PM 6/1/2003]
Old Jun 1, 2003 | 02:13 PM
Corvette0096
Its a roller motor. And the protoplines that I am getting will out flow the Lpe version of the D-port.
Old Jun 1, 2003 | 02:15 PM
scorp508's Avatar
scorp508
Don't get caught up in just flow #s, that isn't all that goes into a head.
Old Jun 1, 2003 | 02:16 PM
65Z01's Avatar
65Z01
Oops, I looked up that 219 cam in Lingenfelter's book and edited the post.
With that motor you will surely need the DRs, enjoy.
BTW, what are your plans for the D-ports?
Old Jun 1, 2003 | 02:30 PM
Corvette0096
BTW, what are your plans for the D-ports?[/QUOTE]
They are called for, MR nuke gets them when I pull them next week. they have 7k on them.
Old Jun 1, 2003 | 10:26 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Nice times! Get some drag rads on their and run in the 12s.
Good job!
To D-port heads #113
