Failed inspection, engine running dirty
Old Jun 1, 2003 | 05:17 PM
Hall1836's Avatar
Hall1836
Default Failed inspection, engine running dirty
Found out previous owner gutted cat, replaced cat passed inspection. Found spare ECM chip in car DELCO HLR 0977. Apparently this is for overseas cars without cats. Has anyone gutted cat and used this chip? Will it pass inspection with this chip in. I don't know whats in the car now, hoping to get information from previous owners. Where is the prom located on a1985 and how hard to change. Older member not computer friendly, much experience in carb cars thanks.
Old Jun 1, 2003 | 05:30 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: Failed inspection, engine running dirty (Hall1836)
The ECM is up underneath the dash on the passenger's side. There is a little cover plate with two hex head screws that cover the PROM for the ECM.
Old Jun 1, 2003 | 06:05 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: Failed inspection, engine running dirty (CorvetteZ51Racer)
It's easy to change but you literally have to stand on your head to see it.
Old Jun 1, 2003 | 10:22 PM
CFI-EFI's Avatar
CFI-EFI
My '84 passes with a gutted cat. In a few weeks we'll see if it makes it with the X pipe and no cat. Good luck and ...
RACE ON!!!
1984 Crossfire
Member NHRA
To Failed inspection, engine running dirty
