DRM brake bias spring install?
Old Jun 5, 2003 | 04:35 PM
jstkrsn's Avatar
jstkrsn
Default Re: DRM brake bias spring install? (ShawnZR-1)
Did mine last Sat. With the large piston held between my shoe soles I held the smaller piston in with a screw driver in one hand, put the snap ring in with snap ring pliers with the otther hand. Took two tries. Not too bad. :D :D
Old Jun 6, 2003 | 12:24 AM
93Quasar's Avatar
93Quasar
Thanks Shawn. Sound like something to consider when I do my upgrade.
Old Jun 8, 2003 | 01:35 PM
myscx's Avatar
myscx
Default Re: DRM brake bias spring install? (myscx)
Well I had the garage install it ,works great ,really evens out the car, front end doesn't dive. :hurray:
[Modified by myscx, 1:38 PM 6/8/2003]
Old Jun 8, 2003 | 03:05 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
good mod works great
Old May 29, 2026 | 11:17 PM
mont95's Avatar
mont95
2nd Gear
New to navigating the forum. Is there a way I can get a picture of the fixture? I'd like to see if it's something I can recreate.
Old May 29, 2026 | 11:20 PM
mont95's Avatar
mont95
2nd Gear
Originally Posted by jackdaroofer
Installing the spring is definitely worth the effort...IMHO
It does work! Brings the rear brakes into play, shortens stoping distance.
If you live near me, or you want to send me the valve assy and the spring, I will install it for you for the cost of shipping only. Like I said, I fabricated a 'fixture" that makes it fairly easy to compress the spring and install the C ring
Happy to do it
e mail me
Jack
PS You will need to bleed the MC and maybe the brakes too
Old Jun 1, 2026 | 10:24 AM
bajasam's Avatar
bajasam
that discussion was 23 years ago, the people may not even be alive any longer!!
Old Jun 4, 2026 | 11:48 AM
KTLarry's Avatar
KTLarry
New Guy
For whatever it’s worth, this fella ET does some nice how-to videos. He did one for the MC spring swap
