Battery Relocation
Old Jun 1, 2003 | 11:49 PM
kkonen's Avatar
kkonen
Default Battery Relocation
Has anyone relocated the battery to the rear of the car? I am considering doing this for weight distribution. I need to know if I can use the stock battery and what needs to be done.
Old Jun 1, 2003 | 11:56 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Default Re: Battery Relocation (kkonen)
one of the autocross guys has done this with a optima gel cell laying sidways.Im sure he will chime in or search archive
Old Jun 1, 2003 | 11:57 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Weight distribution for what purpose? The car already has a near 50/50 distribution already.
Old Jun 2, 2003 | 12:04 AM
BAM92's Avatar
BAM92
:iagree: 50/50. Unless your thinking about stickin a big block in there.
Old Jun 2, 2003 | 12:29 AM
kkonen's Avatar
kkonen
Default Re: Battery Relocation (BAM92)
I autocross. My car is not at 50/50. I can't remember the exact distribution since I last weighed it a year ago. Optimal handling has more weight to the rear. 50/50 is actually a myth. I think optimal is 42/58, if I remember correctly.
Old Jun 2, 2003 | 12:35 AM
Slalom4me's Avatar
Slalom4me
I don't know but my guess is that it probably depends
at least partly on the drivetrain configuration.
42/58 would help me with my wheel spin but it might
be less than optimum for the fwd crowd I run with in
Solo II.
As for the question of who has done it, check out this
current thread for photos posted by gcrouse
http://forums.corvetteforum.com/zerothread?id=570444
[Modified by Slalom4me, 11:38 PM 6/1/2003]
Old Jun 2, 2003 | 01:49 PM
larrybsp's Avatar
larrybsp
You can relocate the battery to the right rear of the car attached to the rear side of the rearmost steel crossmember as far too the right as the gas lines will allow. You need a Stock Car Products 9-1/2" wide battery tray. You have to insert 1/4-20 rivnuts, 4 on the rear side of the beam and 2 on the front side. You have weld mounting brackets to the battery tray and bolt it to the rear cross member. Mine's been on for 5 years. :thumbs: :thumbs:
Old Jun 2, 2003 | 04:50 PM
jburnett's Avatar
jburnett
Default Re: Battery Relocation (larrybsp)
Mine's relocated to the right rear storage compartment...There are pics of my setup as well as another one on the Forum...Just do a search for "Battery Relocation" and you should come up with the thread...If not email me and I'll give you some details...
-Jeb
Old Jun 2, 2003 | 05:30 PM
Steel Blue 91's Avatar
Steel Blue 91
gcrouse did it on his 89. Check here:
It's an exhaust thread but he has a pic of the relocated battery.
Old Jun 2, 2003 | 07:24 PM
swoosh's Avatar
swoosh
Default Re: Battery Relocation (Steel Blue 91)
Recently I saw pics of some guy had his battery relocated to the underside of the car, between the differential a spare tire.
To Battery Relocation
