[Decision Time] Need Advice/Feedback re: Rebuild
My problem is oil pressure. Once the oil is up to temp (180-200), I've seen pressure as low as 9 PSI and a ticking sound coming from the engine. I know what the injector tick sounds like and this is something different. A quick blip of the throttle and the pressure comes up and the tick goes away.
Logic tells me that this pressure is a real reading due to the ticking. I did buy a jug of 15W50 Mobil 1 from Wal-Mart and the pressure is fine now. I get about 15 at idle and 50 at speed. Logic also tells me that this is a band-aid fix and I'm not happy with it.
Considering the overall health of the engine other than oil pressure and after actually verifying with a mechanical gauge the true oil pressure, what would you all suggest? My first instinct is to go with a crate motor due to time constraints and the fact that my Corvette shouldn't be my first rebuild. I don't want to half-azz it either.
I would add that when the motor is out, I would go with AFR heads and either the Lingenfelter modded base/runner/plenum or a SR and the cam they recommend for the SR.
So, given my goals here, would I be better off with a crate engine (ZZ4 or similar) or trying to do a rebuild? Either way will be major bucks spent on a base coupe that's 16 years old that I would never get back except in the smile factor. Is there another option?
Thanks all!
Randy
[Modified by KF9WM's 87 coupe, 6:18 PM 6/2/2003]
Scott
But, the ZZ4 is basically the same block, I would just buy the block and have it built RIGHT the first time, spend the money and you probably will never regret it. If youre shooting for big power go ahead and do the bottom end while you have the money.
Id also use the Accel SR and 219 cam (its the cam they recommend for SR).
