"Autolock"
Old Jun 3, 2003 | 05:22 PM
Orbit's Avatar
Orbit
Default "Autolock"
A friend of mine has a 1989 Vette and has had it since new. A warning light just came on and says "Autolock". Took the car to the dealer for servicing and the dealership doesn't know what the "Autolock" is either. Any information I will pass along. :flag
Old Jun 3, 2003 | 10:08 PM
Wheelman's Avatar
Wheelman
Default Re: "Autolock" (Orbit)
"Anti-Lock" is the light that refers to a malfuntioning abs system component. ;)
Old Jun 4, 2003 | 10:31 AM
C10 JDR's Avatar
C10 JDR
:iagree: and on an 89 you cant pull any codes, because the ABS has its own computer behind the drivers seat in the hatch. Check fuses, clean all connections, remove and clean all wheel sensors, if no joy try a dealer with a scan tool to identify the problem. The parts are too expensive to do trial and error swap-outs.
Old Jun 4, 2003 | 11:58 AM
John Row's Avatar
John Row
1) Check the brake fluid level. If it's low either there is a leak or new pads are called for. This would be a good time to flush the brake fluid.
2) Find a new dealer.
[Modified by John Row, 9:05 AM 6/4/2003]
To "Autolock"
