Tore down engine, back together, runs like crap, HELP
Here's what all we've done to try to correct the problem. Changed plugs (3 times), changed o2 sensor, engine temp switch, Maf sensor, checked plug wires, firing order, chked for sticking injectors, swapped computer, chked fuel pressure.
Engine won't rev past about 3500 RPM's, it just bog's down. I hooked Diacom software up to it and everything seems o.k.. Everyone I've talked to is out of ideas of what to check next.
I would appreciate any suggestions. :mad
[Modified by ham, 11:38 AM 6/4/2003]
If interested, I can put some video's on my web page showing exhaust and you can hear how bad it's running....
[Modified by ham, 11:53 AM 6/4/2003]
Eactly what I was thinking. It either sounds like a cam out of time, not degreed right, the firing order off, valve not opening all the way, ie valve train problems.
What cam is in the car? Was it degreed. Pull the valve covers off while its idling, it going to be messy, to see if you can see any acting weird for example moving as much as the others/loose lash.....you really have to with the simple things then work towards the more complex.
Just a stupid question....your TB is opening all the way isn't it? I don't know why your car wouldn't go past 3k rpms :confused:
[Modified by ski_dwn_it, 2:55 PM 6/4/2003]
Other than that I would agree about the incorrect cam timing idea.
Good luck, hope you get this sorted out soon.
Al
