U-Joints solid or greased?
Old Jun 5, 2003 | 10:43 AM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default U-Joints solid or greased?
Im on my 3rd set of ujoints & am replacing them next week! I have been using greased in the past but was told solid are stronger....What should I use? :confused:
Old Jun 5, 2003 | 10:46 AM
scorp508's Avatar
scorp508
Default Re: U-Joints solid or greased? (yoslambo1@cs.com)
Solid Spicers :yesnod:
Old Jun 5, 2003 | 10:49 AM
yoslambo1@cs.com
Default Re: U-Joints solid or greased? (scorp508)
Where is the best place to buy them? :confused:
Old Jun 5, 2003 | 11:02 AM
Corvette0096's Avatar
Corvette0096
Here are the joints that you need. Spicer 5-800x for the half shafts and 5-786x for the driveline. They are made for aluminium drive lines.Spicer said these are there top dog joints.
Old Jun 5, 2003 | 11:05 AM
yoslambo1@cs.com
Default Re: U-Joints solid or greased? (corvette0096)
Cool thanks...Where do I get them? :confused:
Old Jun 5, 2003 | 11:08 AM
Corvette0096
I would call Spicer and find a dealler in your area or get a hold of Toms drivlines.
http://www.tomsdifferentials.com/
Old Jun 5, 2003 | 11:16 AM
yoslambo1@cs.com
Thanks! :cheers: Any idae how much they cost?
Old Jun 5, 2003 | 11:26 AM
Corvette0096
Here is what happen to me, I did a Dana 44 swap a few weeks back and I told the guy at the Spicer vendor that I need some strong joints. He said to get the non greasable ones.$102 for all 6 joints. Come to find out the sold me the wrong joints for my drivline. So they gave me the correct ones for Free. I hae no clue how much they are. I would imgin they are close to the same price as the other ones.
Old Jun 5, 2003 | 11:46 AM
Dominic Sorresso's Avatar
Dominic Sorresso
corvette0096,
When I checked recently, the 5-800X joints are 35-37 bucks. Think that's why some shops will use the 5-799X ($23 each) for the half shafts and then use anti-seize on the caps. These are solid joints.
[Modified by Dominic Sorresso, 10:53 AM 6/5/2003]
Old Jun 5, 2003 | 11:48 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
http://forums.corvetteforum.com/zerothread?id=574040
Old Jun 5, 2003 | 12:01 PM
Corvette0096
Default Re: U-Joints solid or greased? (Dominic Sorresso)
corvette0096,
Here is the correct joint.
You will see two thing diffrent in this picture that you will see with the joints you have in your car now....
1. Clips are not copper.
2. The Caps are not shiny looking. They are a diffrent metal.
Why did they make that joint? Cause we have aluminium drivelines. What happens when you use the other joint? electrolysis! Does anti seize on the end of the cap prevent electrolysis? I would think not. That is not where the joints and shaft make contact.....Looking at the Guys sig I would say he will not try and cut corners on his car. :)
Old Jun 5, 2003 | 12:02 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Got mine from NAPA.
Old Jun 5, 2003 | 12:10 PM
yoslambo1@cs.com
corvette0096,
Thanks...Im ordering them today! :cheers: You are right I dont want to cut corners! :smash:
Old Jun 5, 2003 | 12:22 PM
yoslambo1@cs.com
Rich, thanks for all the help! :cheers: I just ordered them. $20.50 each on the 5-800x & $16.80 on the 5-786x...$115.60 for all of them! :D
Old Jun 5, 2003 | 12:30 PM
Corvette0096
Glad I could help.. :cheers:
Old Jun 5, 2003 | 01:21 PM
Dominic Sorresso
corvette0096,
I spread the anti-seize in the yoke area and around the cap and clip. Not disputing the use of the correct joints. But I think anti-seize is a workable alternative that's being used by a number of shops I have respect for. I also use it on my spark plugs for the aluminum TFS23d heads I have. The heat in that area accelerates the electrolysis process.
Old Jun 5, 2003 | 03:52 PM
Corvette0096
corvette0096,
You should use anti seize on all bolts where they contact aluminum. Header bolts, Spark plugs,etc.......As for the spreading it on the U-Joints? I am really pickey with my car so I did it the right way...Plus you said you paid $23 for the joints and he is getting them for $20.50 for the correct one. Plus the cost of anti sieze. I see a bigger saving in getting the right one for the application. And here is the best part..Piece of mind.. You have a good day I am finished.. :seeya
[Modified by corvette0096, 12:58 PM 6/5/2003]
To U-Joints solid or greased?
Old Jun 5, 2003 | 07:20 PM
J Z06's Avatar
J Z06
I honestly can't remember the name of my universal joints. They did have grease fittings on them. We replaced all three shafts. They felt scratchy when you turned them(Where the needle bearings we're). Now, they've been in there a while and are fine.
Three sets Eric? How come so many? I replaced mine(originals) around 90K.
:cheers:
Old Jun 5, 2003 | 07:32 PM
yoslambo1@cs.com
Default Re: U-Joints solid or greased? (Jay D 90 383)
:cheers:
I replaced them each time my tranny blew! :eek: I figured while Im there I should replace them. :yesnod: Now with the real engine I definetly want new ones (best I can buy) as I plan on racing the 27th! :D Are you gonna line up against me? :jester
Old Jun 6, 2003 | 06:11 AM
396 Roadster's Avatar
396 Roadster
Tonight I just installed the Spicer 5-626X 's on my driveshaft, and they are really nice pieces. I plan on doing the half shafts when I do my gear swap. I'm still confused as to what part # is correct for the half shafts though.
