A neat little tip!!!
Old Jun 6, 2003 | 07:28 PM
Frank C's Avatar
Frank C
Default A neat little tip!!!
I did a compression check today and stumbled onto a clever tip, in my opinion. Naturally I had to pull all the plugs leaving the wires dangling. I went into the kitchen junk drawer for the masking tape to use in numbering the wires because I don't have those neat wire looms. I saw the wife's bag of wire twists and (are you ready) those thin square plastic bread and roll bag fasteners. You know the kind, about 3/4 square with a pinching slot cut in so you can force it on to the twisted bag end. Well I mark them 1 through 8 and slip them over the spark plug wires as I remove them from the plugs. No tape to remove, no wires to mark and hopefully no confusion. They're is now a set in my tool box. Not bad huh. Try um you'll like um......Frank
Old Jun 6, 2003 | 07:37 PM
KY Vette's Avatar
KY Vette
Default Re: A neat little tip!!! (Frank C)
Sounds like an excellent idea! Thanks for the tip!
:thumbs:
Old Jun 6, 2003 | 07:42 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
So.........what's keeping the bread from drying out? :lol:
Old Jun 6, 2003 | 07:59 PM
faj's Avatar
faj
Default Re: A neat little tip!!! (brdd)
TADA! here's where that useless masking tape comes in handy :lol:
Old Jun 6, 2003 | 08:25 PM
Caboboy's Avatar
Caboboy
Nice idea........ very nice! :thumbs:
Old Jun 6, 2003 | 11:18 PM
Dan Parker '96's Avatar
Dan Parker '96
For about $4 you can go to Autozone (or some similar store) and pick up the little numbered plastic collars that go over the wires. Makes wire ID easy and looks pretty good as well.
Old Jun 6, 2003 | 11:27 PM
Netnarc2's Avatar
Netnarc2
Default Re: A neat little tip!!! (Dan Parker '96)
Very good idea and it doesn't cost a cent. Usually, Corvette = $$$$$. :cheers:
Old Jun 7, 2003 | 01:49 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
:thumbs:
Good one !!!!!!!!!!!!!
Old Jun 7, 2003 | 01:56 AM
TA's Avatar
TA
Couldn't you just do remove the wires one by one as you test each cylinder?
Old Jun 7, 2003 | 03:30 PM
Jimbo93's Avatar
Jimbo93
:lolg: sounds like a lotta doe to me. :D
Old Jun 7, 2003 | 03:57 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: A neat little tip!!! (TA)
A proper compression test involves cranking with all the plugs removed and the throttle open.
What *I* want to know, is WHY did you have EIGHT of these on hand??? You must keep house, like *I* do.
RACE ON!!!
1984 Crossfire
Member NHRA
Old Jun 8, 2003 | 10:01 AM
Rick92's Avatar
Rick92
sounds like a good idea to me :cheers:
Old Jun 8, 2003 | 11:32 AM
RichAshley-Black99's Avatar
RichAshley-Black99
Default Re: A neat little tip!!! (Caboboy)
Thats a good Idea! wouold have never thought of that :cool:
Old Jun 10, 2003 | 11:23 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Congrat's.....thanks for sharing your idea's.....I will use next time....
thanks
tony
:cheers:
Old Jun 11, 2003 | 04:48 AM
gears's Avatar
gears
Cool...Hints from Heloise.
Old Jun 11, 2003 | 05:31 AM
skeet's Avatar
skeet
Default Re: A neat little tip!!! (gears)
Just a caution- always change the plugs by the "sell date" or your plugs will get moldy.
Old Jun 11, 2003 | 06:38 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: A neat little tip!!! (skeet)
:lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg:
just cut away the moldy parts, you know like cheese, and screw 'em back in then away you goooooooooo............
To A neat little tip!!!
Old Jun 11, 2003 | 09:10 AM
ROADAPPLE's Avatar
ROADAPPLE
Great tip, thanks :hurray:
Old Jun 11, 2003 | 09:42 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Thanks that is a good idea. :yesnod:
Old Jun 11, 2003 | 10:55 AM
86shark's Avatar
86shark
any ideas for my coca cola caps, plenty of them here. :seeya
