89' Diag. Code HELP
Old Jun 7, 2003 | 02:34 PM
69L68's Avatar
69L68
Default 89' Diag. Code HELP
This might should have been OT, but I am in a pinch. I have an 89' GMC pickup truck this is not running well. I cannot find my shop manual but I was able to desyphire the diag. code. The fault code is "4-2". I believe that all of GM used the same format that year. Can someone tell me what that failure code is for, or direct me to a site were I can get it?
Thank you,
Steve
Old Jun 7, 2003 | 08:21 PM
mr.beachcomber's Avatar
mr.beachcomber
Default Re: 89' Diag. Code HELP (69L68)
Steve, if the '89 codes are all the same, then you have an Electronic Spark Timing (EST) circuit failure code. It could be due to:
1. a faulty ignition module
2. a faulty connection/ground between the ignition module and the four-wire connector
3. a faulty ECM
4. a Mem-Cal (chip) not fully seated in the ECM.
Hope this helps! :seeya
- Greg Smith, '89 Coupe
