Non-working 1985 Horn
Old Jun 9, 2003 | 05:10 PM
wmm1955's Avatar
wmm1955
Default Non-working 1985 Horn
I have a 1985 coupe that the horns are not working. I have tested the horns themselves and they work fine. I have voltage (5 volts) present at the horn contact plate on the steering wheel. Now for the real question, where is the horn relay located? The reference material that I have says it is located near the fuse panel, but I have not been able to locate it. I also understand that it is the same relay as is used by the rear hatch latch, so I have some idea as to what it looks like. Any help would be greatly appreciated. :banghead:
Old Jun 9, 2003 | 07:56 PM
greg84's Avatar
greg84
Default Re: Non-working 1985 Horn (wmm1955)
hi,your horn relay is above the fuse box and is taped to your i/p harness,good luck greg84 :cool:
Old Jun 10, 2003 | 10:29 AM
wmm1955's Avatar
wmm1955
Thanks greg84, will see if it's there. :cheers:
Old Jun 10, 2003 | 04:02 PM
85vetteguy's Avatar
85vetteguy
I believe the horn relay is located behind the DIC(driver information center) on the 85. Remove the bezel, the one around the stereo, and remove the dic. You will see the relay and also a fuse. I'll bet the fuse is probably blown. Good luck, Guy
Old Jun 10, 2003 | 07:03 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
You know I replaced the horn button emblem with a gold plated one, and while doing this I broke the metal behind the horn button......do you know where I can get a new one.....???????????????? Its an '84.....
tony
:eek: :eek: :flag
[Modified by oldace84, 4:03 PM 6/10/2003]
Old Jun 10, 2003 | 09:19 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Default Re: Non-working 1985 Horn (85vetteguy)
Ding Ding Ding Ding!!!
:iagree:
Oldace84 get on ebay-corvette parts and look for a guy like Redneck43 and email him. I'll bet he can help.
To Non-working 1985 Horn
