Help...
Old Jun 10, 2003 | 07:38 PM
RiceEater35th's Avatar
RiceEater35th
Default Help...
Whats the amount of TQ's i need to tighten the 36mm bolt that holds the rotor onto the wheel bearing/hub. Thanks in advance..
:spam :cheers: :cool:
Old Jun 10, 2003 | 07:56 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Help... (RiceEater35th)
For the front caliper bolts apply 137 lbs ft. and immediately recheck torque on both bolts. Use new bolts (and washers) that come with the thread-lock already applied.
Sooo...your 35th is also a "rice eater"...well done. :yesnod:
Well...they don't make me sick...but within an hour I'm hungry for another.
[Modified by 65Z01, 9:48 PM 6/10/2003]
Old Jun 10, 2003 | 08:01 PM
MrNuke's Avatar
MrNuke
Default Re: Help... (65Z01)
...........Just make sure to spit them out... Otherwise you'll get sick from all the LED's and large chucnks of metal (their mufflers). :jester
Old Jun 10, 2003 | 09:32 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Help... (MrNuke)
:lolg: :lolg: :lolg:
To Help...
