I am somewhat of a handling freak... am thinking about installing polyurethane bushings...
1. Is it worthwhile to do if the current rubber is still okay? (62,000 mi)
2. Can you do selected areas (sway bars, lower control arms) and enjoy benefit without doing the whole car?
3. Am I insane to even consider doing this myself?
Re: polyurethane bushings for dummies (TankerVette)
If you are mechanically inclined AND own tools you can do it!!!!
I have Energy Susp. and the CAMBER BRACE and together they ROCK!!
My 89 vert (IMO)can probably out handle the 98 in a tight turn. Granted i have base susp. in the 98. But you turn the wheel in the 89 and hang ON!! You be around that corner in no time! I am not knocking my 98( I LOVE it!)But the vert is no slouch any more!!
GET THE BUSHINGS,NO REGRETS HERE!!! I did the whole car except for sway bars front and rear.
DO IT!!!!
Matt
I did the polyurethane and have no regrets. I would do the whole car. I did half one week and the other half the second and it was pretty obvious. It made a huge handling improvement, to the point I would put it up against the 98 and feel confident it would be right there with it, if not better :yesnod:
I did it all myself. I used a three prong wheel puller to pull/push the old bushings out and install the new ones. Some guys burn them out, but that was just too messy for me. The bigger bushings can be drilled and pulled out. Search the archives there are a bunch of us that posted, how we did it or asked questions.
IMO yes go ahead and do the polyurethene bushing : trailing arms(controls arms) cross brace etc.
No complaints about change out and makes a large improvment: i used shop press to remove: just takes i little time :iagree:
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Personally, I wouldn't do it if they don't already need replacement. I bought some, but ended up returning them. Now, I do all my own work on this car, engine, clutch, lowering etc, but replacing all the bushings is a MAJOR undertaking.
I guess if you're already jumping into it, make sure you have a breaker bar, a sledge, and SOAK all the bolts several times in the days leading up to when you start work. The steel bolts that go into the aluminum knuckles are a PITA. You might want to consider using anti-sieze on install, but DON"T use locktite on aluminum parts. :nono:
thanks for the opinions... am going to do it...
Excellent! That's in the spirit of C4 Tech! I did the complete Energy Suspension kit. Absolutely love it! I had never done any work like that before. Give yourself plenty of time maybe like a week and have a press or a vise standing by. Don't burn the old ones out. I just drilled them out. Get a few drill bits. Check the archives here too. Lots of good info. (Like tap out the diff carrier's mounts sleeves)
If ya get that kit and run into any probs like missing sleeves or anything, Greg Corey is ES customer service rep. Great guy and service. He'll do right by you.
Get a camber brace also!
Tank on and watch out for those icebergs :lol:
Re: polyurethane bushings for dummies (89 Paul in Cal)
I also installed the ES master kit. I got the black ones and was pleasently surprised they are graphite impregnated. It took me a while, but I wasn't rushing it because my shocks were being re-valved at Bilstein.
I didn't run into many problems and mostly used a 2 prong 6" puller and an electric drill. It took me a while to figure out the rear diff carrier has an outer sleeve that needs to be removed.
I installed the washer on the front upper control arm backwards and had to cut the poly bushing out. I called ES customer support and they sent a new one out right away, at no charge. :thumbs:
BTW, I'm very happy with the stiffer shocks, poly bushings and lowered suspension. The ride is greatly improved.
