396 crank quesiton...
Old Jun 10, 2003 | 06:09 PM
Z06_BluByU's Avatar
Z06_BluByU
Default 396 crank quesiton...
Does any vender offer a 396 (3.875) stroke crank that is not forged? This is the make it or break it for me on the 396 vs. 383 debate
Old Jun 10, 2003 | 07:21 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: 396 crank quesiton... (BluByU)
No they do not.
Old Jun 10, 2003 | 08:08 PM
Rich B.'s Avatar
Rich B.
IIRC, the reason they don't offer a cast 396 crank is because of the journal webs...(the unmachined areas that connect the journals)...With the 3.875" stroke, they are just too "stretched" to withstand the stresses of a "reasonable" redline in a cast configuration...
But I'll tell you, I'd spend the money in a second to get the forged 396 over the 383...
Go for it!!! :thumbs:
Old Jun 10, 2003 | 09:12 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: 396 crank quesiton... (Vette92)
so in my daily driver project rebuild.. that i'd just like to make some resonable numbers with... maybe someplace between 310-370 rwhp.. what would be the least expensive way to a 396? can it be done for less than 2000.00 total if i do all the assembly etc?
[Modified by BluByU, 8:37 PM 6/10/2003]
Old Jun 10, 2003 | 09:53 PM
CFI-EFI's Avatar
CFI-EFI
Give, Ohio Crankshaft, a call. Their ad in "National Dragster" only shows up to 3.75" stroke, in nodular iron. They DO show a 3.875" stroke shaft for $425.00. 800-333-7113. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
Old Jun 10, 2003 | 11:11 PM
cprgmr's Avatar
cprgmr
I think you'll be around $2,500 for just the crank, rods and pistons (all forged). And don't forget all of the other things you'll need (align bore, block cleaning/clearance work, bearings, rings, tools, gaskets, etc).
Old Jun 11, 2003 | 11:19 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: 396 crank quesiton... (cprgmr)
If you are just looking for 310-370 RWHP, then just do a cast 383 and put a hotcam stick in it. Should put you around 330rwhp. Want more than that, just do head work.
To 396 crank quesiton...
