730 ECM SD location/swap
Old Jun 11, 2003 | 06:47 PM
Fast_vette89's Avatar
Fast_vette89
Default 730 ECM SD location/swap
swaped my 89 over to SD, everything went well. But i'm tired of having a ECM sitting on my floor board. where did you guys put them?? b/c the MAF computer is different.... wont fit up there. theres a thing that "holds" it... what did you guys do??
Old Jul 9, 2003 | 11:51 PM
drive it's Avatar
drive it
Default Re: 730 ECM SD location/swap (Fast_vette89)
ttt.....
Old Jul 10, 2003 | 11:28 AM
-=Jeff=-'s Avatar
-=Jeff=-
if the plugs are ont he side as you put it up from it floor it will not fit?
You could remove the ECM bracket int he car and modify it to fit better too
Old Jul 13, 2003 | 02:28 PM
Fast_vette89
Default Re: 730 ECM SD location/swap (-=Jeff=-)
It's all done. the stock 165 ECM plastic housing would not come out very easy...the bolts were a PITA! so i just cut it out, and BADA BING! the new ecm went right in no probs.
Old Jul 14, 2003 | 10:41 PM
drive it's Avatar
drive it
Thanks!!!
To 730 ECM SD location/swap
