Camber brace users.....stop by
Jun 12, 2003 | 08:08 PM
I'm considering the camber brace for my car. The question, because it's "boxing" in the camber assemblies does the car need to be realigned once it is installed????? Or is it just bolt on and plug and play? Let me know and thanks
Kitt
Jun 12, 2003 | 08:16 PM
Re: Camber brace users.....stop by (kittmaster)
It doesn't change your alignment. It prevents/reduces front-end flex and maintains the alignment you have. Specifically keeps the negative camber you are running from decreasing during hard turn-in. Bolt it in, shim to eliminate any gaps, tighten, have fun :cheers:
Jun 12, 2003 | 08:18 PM
Re: Camber brace users.....stop by (NavyVet)
looks like I'm gonna have to get mine......lol.......thanks for the heads up
Jun 12, 2003 | 08:23 PM
You'll love it... :yesnod:
Jun 12, 2003 | 08:25 PM
Re: Camber brace users.....stop by (FoolCrzy)
trying to call them now to see about 2nd or 3rd day, hope to have it in before the caravan......i'm getting excited about this trip...... :D
All the last minute little details......I got goose bumps..... :lol:
Jun 12, 2003 | 11:57 PM
Get it!! You'll be glad you did! Like was said, no alignment is needed. Dave at R-D Racing is great to deal with. :thumbs:
Jun 13, 2003 | 01:29 AM
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Re: Camber brace users.....stop by (Gary96LT4)
Just make sure that biznitch is TIGHT. Mine came loose and cost me $15.00 in a shim pack.
Hearing the tink-tinkle of parts dropping out of your engine bay onto the pavement is a disconcerting sound. :eek:
Jun 13, 2003 | 08:51 AM
The short answer is no. The long answer is still no. It's not required. I chose to install mine before my annual 4 wheel alignment.
Jun 13, 2003 | 03:10 PM
Re: Camber brace users.....stop by (stormy652)
i am thinking i will buy one in the next few days...what kind of shims do i need? where should i get them? Thanks!
Jun 13, 2003 | 03:31 PM
Re: Camber brace users.....stop by (konroh)
It comes with everything you need.. just put it in, use the provided shims and tighten down..
It make a world of diffence on the C4, worth every penny
Jun 13, 2003 | 03:40 PM
St. Jude '03 thru 14,'25
just put it in... waiting for dry pavement... but already worth the $180...
Jun 13, 2003 | 06:09 PM
I just ordered it today. It will be here on Wednesday, few days shy of the caravan......will make an interesting trip with the top off. Can't wait and thanks for the replies guys........ :cheers:
Kitt
Jun 13, 2003 | 11:07 PM
I have one. It is da bom!!!!!!!!!!!
Jun 16, 2003 | 11:12 AM
Just installed one over the weekend.
Went in easy enough. Just make sure you have a grinding wheel handy. The brace needed a little grinding on the bottom of the plate to clear one of the frame bolts.
Have not test drove it yet.
Paul :reddevil
Jun 16, 2003 | 11:30 AM
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Re: Camber brace users.....stop by (uralman)
:confused: :confused: That's the very first time I've heard of having to grind anything on the brace!!! Can you elaborate on where you had to grind it and where it had to clear? Take some pictures too!!
BTW, that brace is steel. I hope you repainted it so it doesn't begin to rust.
Grinding really?........the shims didn't clear the bolt properly??.....
Jun 16, 2003 | 11:35 AM
Re: Camber brace users.....stop by (ShawnZR-1)
That's a new one for me as well. Haven't heard of someone having to grind to install.
Jun 16, 2003 | 11:37 AM
not the shims it was the corner of the plate. once I ground off about 1/8" it fit fine. It still needed to be shimmed.
Paul
Jun 16, 2003 | 11:53 AM
Any pics of the grind and the installation? Mine will be here on Wednesday. Would like to see what your describing
Chris
