Rim Polishing - 1st One Complete - WOW!!!
Re: Rim Polishing - 1st One Complete - WOW!!! (Atok)
Hurry up and get done, so you can do mine. They are going to look great when you get all 4 done.
they look good :thumbs:
i just finnished mine, i sanded all the way to 1500 grit/wet, then polished :yesnod:
alot of work, i'll send them out next time :cheers:
Side bar question,
Did you look at the codes & stampings on the back side of the rim. I've got some sawblades I picked up & plan on polish or chrome. they're 8.5 & 9.5 17.2 with 56 offset. Funny thing is they are stamped Japan. They also have little circle (size of a pencil eraser) with codes like 92 etc.
Were any GM sawblades sourced in Japan?
Thanks!
Thanks!
Re: Rim Polishing - 1st One Complete - WOW!!! (ninetyfivevette)
I replaced my 92 wheels with the ZR wheels. I'd like to polish the original wheels for future use. You say start with paint stripper and then go to the red compound bar? Does the paint stripper hurt the tires? If so, did you take the tires off and then do the job? Has anyone tried bringing the wheels to a "boil out tank" to get the paint off or would that be too tough on the aluminum?
#33
1 Post
Re: Rim Polishing - 1st One Complete - WOW!!! (Strick)
I'm looking into having the wheels chemically stripped then hot tanked and either polished or powdercoated. Haven't got around to it yet. Really don't want to have the car down for the amount of time it will take.
#34
Re: Rim Polishing - 1st One Complete - WOW!!! (Steel Blue 91)
I found the fastest way is to use a machine buffer after 400-600 grit wet-n-dry.
I would be careful about tanking the wheels - be sure the owner of the tank knows aluminum.
#37
Re: Rim Polishing - 1st One Complete - WOW!!! (PoloGrnC4)
For those of you who asked for a full side pic with the complete rims. Not the best pics I took but not bad.
:hurray:
:hurray:
#38
Cruise-In I Veteran
Cruise-In II Veteran
Re: Rim Polishing - 1st One Complete - WOW!!! (Pete89)
Looking good :cheers: Are those tires directional?Looks like they are mounted the wrong way
They are mounted wrong.....Dude, the wheel is mounted backwards. :confused:
#39
Re: Rim Polishing - 1st One Complete - WOW!!! (Zora)
Ya ya, see a previous post in this thread....I finished the right side wheel first, had better light on the left side for a picture, so I stuck the finished right wheel on the left side to get a picture. Don't worry, they are on the proper side now. :)
Man you guys are observant!! :eek:
:cheers:
:cheers:
#40
I am going to setup one of the CNC's at work to do the polishing for me sometime this summer... Totally painless :)
