Ceramic Brake Pads!!!???
Old Jun 12, 2003 | 09:38 PM
honas's Avatar
honas
Default Ceramic Brake Pads!!!???
I didn't even know they existed! Any opinions? How much? Which ones? Thanks alot! Ben.
Old Jun 12, 2003 | 09:44 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Ceramic Brake Pads!!!??? (honas)
:D They make just as much dust, just a lighter shade of black :rolleyes:
They are tougher on roters
They do seem (imho) to stop a little better
what are you using now?
:seeya
:steering:
Old Jun 12, 2003 | 09:54 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Ceramic Brake Pads!!!??? (jackdaroofer)
:seeya
:steering:
:iagree:
NAPA makes Ceramic pads called Ceramix. Everything Jack said applies.
Old Jun 12, 2003 | 10:02 PM
StealDads67's Avatar
StealDads67
Default Re: Ceramic Brake Pads!!!??? (Mr Mojo)
WE use them all the time in the shop...... (Ceramix)... They are a quality brake pad.
Old Jun 12, 2003 | 10:11 PM
honas's Avatar
honas
I still have origional stock pads. Only 18K miles on the car. Ben.
Old Jun 13, 2003 | 08:10 AM
Tom Piper's Avatar
Tom Piper
On my '92, I've had the stock 12" front brakes, the J55 13" front brakes, and now the 13" C5 brakes. On a scale of 1 to 10, with the same type of brake pads, if the stock brakes are a 1 and the C5 brakes are a 10, then I rate the J55 brakes a 7. However, when I had the Performance Friction carbon metallic brake pads on with the J55 brakes, my rating would be a 10 (I actually locked up my anti-lock brakes with this setup). But, after 2000 miles, I took the Performance Friction pads off, and I will never put them back on because of the copious amount of black dust in normal driving (my front wheels would be solid black in 100 miles with the rear wheels clean). When that black dust got water on it, it started to etch my wheels.
So, I now have C5 brakes with ceramic brake pads -- Imagine what the C5 brakes would be like with Performance Friction pads.
As a previous post said, the ceramic pads make dust, it isn't as easy to see that dust.
Tom Piper
Old Jun 13, 2003 | 10:37 AM
Rich_01659's Avatar
Rich_01659
Default Re: Ceramic Brake Pads!!!??? (Tom Piper)
I use them. They stop better, in wet conditions, than oem.
Old Jun 13, 2003 | 11:00 AM
C4SMAJ's Avatar
C4SMAJ
Default Re: Ceramic Brake Pads!!!??? (Rich_01659)
Ive had them for quite a while...they work well wet or dry...still have dust but its a lighter color so not so noticeable...I have the NAPA Ceramix... :seeya
Old Jun 13, 2003 | 03:30 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
What kind of shape are your rotors in.....or are you going to install them new also???????
thanks
tony
:smash:
To Ceramic Brake Pads!!!???
