Checking for Codes Set - No Scanner
Old Jun 13, 2003 | 06:42 PM
Jeff Blowers's Avatar
Jeff Blowers
Cruising
Default Checking for Codes Set - No Scanner
Is there a way to check for codes possibly set without having some type of scanner? Like jumpering across a couple of pins on a connector and watching the check engine light flash in a pattern? If so, can someone describe connection points and where I might find it.
Old Jun 13, 2003 | 06:55 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Checking for Codes Set - No Scanner (Jeff Blowers)
This site will help....... http://www.c4vettes.com/
Old Jun 13, 2003 | 08:31 PM
Jeff Blowers
Cruising
Default Re: Checking for Codes Set - No Scanner (lou sylvestri)
Thanks. That site is really helpful.
To Checking for Codes Set - No Scanner
