Beam Plates
Old Jun 13, 2003 | 06:59 PM
Stingray1970's Avatar
Stingray1970
Default Beam Plates
Beam plates from ZFDoc came this week. High quality workmanship, should be a lot easier to install that #%*#*%/* beam now.
Old Jun 13, 2003 | 07:16 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Beam Plates (Stingray1970)
:confused:
A joke right?????
And if so why???????
If not...what are you talking about.....???
thanks
tony
:confused: :confused: :confused: :eek: :eek: :confused: :confused:
Old Jun 13, 2003 | 07:28 PM
Stingray1970
Default Re: Beam Plates (oldace84)
Tony,
The beam plates reduce the twisting at the fastening points of the driveline support beam. This occurs under heavy loading ( hard acceleration). The faactory's solution was sealant, appears to be some type of epoxy. You can check them out at http://www.ZFdoc.com
from an older ace
Old Jun 14, 2003 | 07:04 AM
The Bus's Avatar
The Bus
Everyone should install these on their Vette. Makes installation a snap.
Old Jun 14, 2003 | 07:17 AM
chucks88's Avatar
chucks88
Default Re: Beam Plates (The Bus)
I'm a member of the club. They helped in keeping my convertible from kicking out to the right upon acceleration and deccelaeration :thumbs:
Old Jun 14, 2003 | 08:59 AM
Hammer's Avatar
Hammer
Default Re: Beam Plates (chucks88)
Mine are sitting in my house ready for install, couple more weeks...
Jim
Old Jun 14, 2003 | 09:42 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I'm sorry, but are they really worth what he charges for them? I've seen what they looklike, what I haven't seen is what they look like on the car or next to something where I can compare the size.
It seems that all that $$$ for some small pieces of metal, well it just doesn't seem right.
Old Jun 14, 2003 | 09:46 AM
FoolCrzy's Avatar
FoolCrzy
Default Re: (Mr Mojo)
I tend to agree...I guess I just don't understand them.... :confused:
I hope it helps those who have bought them... :cheers:
Old Jun 14, 2003 | 10:04 AM
chucks88's Avatar
chucks88
Default Re: (FoolCrzy)
:yesnod: For what you get they are pricey. I think there are up to about $180. I picked mine up over a year ago for $140. Still pricey for what you get but to pay $140 for the results I received was well worth it.
Old Jun 14, 2003 | 11:05 PM
Stingray1970
They do make for a tighter clamping action of the driveline beam. GM attempted to do the same with the sealant they installed at the factory. However, the beam plates seem like a better solution. Another reason for using them is the nuts are caged on the top plates. That sure beats trying to tighten the bolts and get a wrench into the tight space on top of the beam to hold the nut. Just my reasons for buying them.
Old Jun 14, 2003 | 11:38 PM
silver & red CE's Avatar
silver & red CE
I don't claim they're a bargin, esp considering the price of a camber brace..if I was paying $100/hr to have someone work on my Vette and he told me I needed buy them so it was easier to install the c-beam, I skip 'em. But since I am my own mechanic, I need all the help I can get. The beam plates make it easier and they must help stiffen the drivetrain. If they're $180 now, it won't be long before someone makes them for $100, they aren't rocket science.
Eric
Old Jun 15, 2003 | 04:23 AM
BIG JIM 54's Avatar
BIG JIM 54
I think I finally found out why my car wants to kick out to the right when high RPM shifting from 1st to 2nd thanks to that ZF website and you for posting it.
Rather than spend the $179.00 though, I think I'll make my own from steel plate.
Thanks again,
BIG JIM
Old Jun 15, 2003 | 04:47 AM
BrianS's Avatar
BrianS
I thought about this mod but instalation looks like a PITA!! Maybe when time comes to replace the rear gears...
Old Jun 15, 2003 | 11:08 PM
bogus's Avatar
bogus
Default Re: Beam Plates (BrianS)
I have them... and they are very impressive.
The end result? The elimination of the right hand kick to the rear wheels under hard acceloration.
Old Jun 15, 2003 | 11:48 PM
superlund's Avatar
superlund
Default Re: Beam Plates (bogus)
They are expensive but I don't believe the price is unreasonable for a limited production / low volume item. You could knock off a set for less but the guy is in business to make money...To his credit he is paying close attention to details with top notch materials, fabrication, & processing procedures. I wouldn't want to set around and heli-arc those up all day for much less.
Specifications: Material - 30302 stainless steel, Construction - T.I.G. welded, Fasteners - New GM self-locking nuts, Weight - 1.65 lbs. (per vehicle set), Finish - Silicon bead blasted
To Beam Plates
