I'm thinking about doing this conversion. click here. What else would I need that the kit doesn't include? Would I need a larger TB and injectors? Would the computer need to be re-programed? Any other suggestions would be appreciated. Thanks!
According to add you are going to have to change the optispark to one that fits the 95-96. Probably have to change timing cover too. Since there is a cam change you will have to reprogram computer. Your 92 could be upgraded to the 24lb injectors since ours ( I have a 92 also) came with 21 or 22lb injectors ( can't remember which one). A 52tb would probably help too since airflow has increase due to heads and cam.
I posted this same question and link earlier this year.
I believe that the general response I got was that it was better to simply get the hot cam kit and spend that same money on getting your LT1 heads cleaned up. I didnt get a lot of responses, so I will sit and watch this one too.
But - that kit does include a ton of gaskets and seals - probably many of which could stand to be replaced in your 92. (I know my 93 needs them).
