Piston rings.. Plasma moly vs. chrome
Old Jun 16, 2003 | 11:47 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Piston rings.. Plasma moly vs. chrome
what the hell is the difference and which on is better?
Old Jun 16, 2003 | 05:01 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: Piston rings.. Plasma moly vs. chrome (BluByU)
anyone?!?! ttt
Old Jun 16, 2003 | 06:27 PM
honas's Avatar
honas
Ask this guy. He knows it all. lcvette1@aol.com
Old Jun 16, 2003 | 11:51 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Piston rings.. Plasma moly vs. chrome (honas)
plasma moly put them in and forget them :cheers:
Old Jun 17, 2003 | 12:40 PM
grumpyvette's Avatar
grumpyvette
Default Re: Piston rings.. Plasma moly vs. chrome (CORKVETTE1)
http://www.babcox.com/editorial/us/us20114.htm
http://www.babcox.com/editorial/ar/ar110060.htm
http://members.aol.com/carleyware/library/ar293.htm http://www.babcox.com/editorial/ar/ar90058.htm
http://www.aera.org/Tech/tb687r.htm
http://www.hastingsmfg.com/service_tips.htm
http://www.kb-silvolite.com/speclear.htm
http://www.sswesco.com/ss/sspow.htm
http://www.totalseal.com/totalseal3.html
http://www.aera.org/Members/EngineTe...1296/page3.htm
http://www.hastingsinc.com/Service%2...efinishing.htm
http://www.precisionrings.thomasregi...ings/page5.htm
http://www.madhousemanagement.com/tavia/cat17.html
this type (ABOVE) is far easiers to line up (INCORRECTLY) to the block surface at a slight angle that allows the rings to partly pop out from under its lower edge just as the rings leave the lower edge of the compressor and enter the cylinders bore, [b] now Im not saying you can,t do it, just that its far easier to do it correctly with this type of ring compressor.
http://www.jegs.com/cgi-bin/ncommerc...85&prmenbr=361
[Modified by grumpyvette, 6:02 PM 6/17/2003]
Old Jun 17, 2003 | 01:33 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: Piston rings.. Plasma moly vs. chrome (grumpyvette)
I wouldn't use chrome rings. They are hard on cylinder walls and can take a long time to seat.
Old Jun 17, 2003 | 02:11 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: Piston rings.. Plasma moly vs. chrome (tpi 421 vette)
moly it is.. thanks guys!!
To Piston rings.. Plasma moly vs. chrome
