help!!!!!!!!
Old Jun 16, 2003 | 07:53 PM
mtlwiz's Avatar
mtlwiz
Default help!!!!!!!!
91 l98 spd. been running great then all of a sudden, coughs and backfires in intake, barely runs when you try to go offidle,,, cap rotor and timing are ok and it seems it does this when it goes into closed loop, almost as if leaning way out!, ecm is about a yr old and was tuned about 300 miles ago, new fuel filter and injectors,, like i said was running perfect till all of a sudden?????? any hints as to what may cause this, im no car dummy but i am a little lost on this???????????????????? thanks in advance
Old Jun 16, 2003 | 08:32 PM
ittlfly's Avatar
ittlfly
Default Re: help!!!!!!!! (mtlwiz)
Are you getting the SES light? Codes?
Old Jun 16, 2003 | 08:42 PM
mtlwiz's Avatar
mtlwiz
oh and by the way no codes or ses lights. just dies and backfires the second you try to rev past idle whether car is sitting and its even worse when you try to put it under load.but it idles fine!
Old Jun 16, 2003 | 09:37 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
might be fuel pump. Check the pressure at the rail when it's acting up.
Old Jun 16, 2003 | 10:44 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
:iagree:
To help!!!!!!!!
