GEARING
Old Jun 17, 2003 | 11:01 PM
SPEED750's Avatar
SPEED750
Default GEARING
What rear-end gear do I have if I'm running 60 mph in second (zf 6 sp) at 5400 rpm.The tires are stock height.THANKS! :confused:
Old Jun 18, 2003 | 02:07 AM
BAM92's Avatar
BAM92
Default Re: GEARING (SPEED750)
3.45:1 You should be turning 1400 rpm at 60 in 6th gear.
Old Jun 18, 2003 | 03:37 AM
BIG JIM 54's Avatar
BIG JIM 54
It is impossible to get a low enough gear ratio in a Dana 36 or 44 to run 5400 RPM at 60mph in 6th gear even with go-cart tires.
Old Jun 18, 2003 | 07:48 AM
FoolCrzy's Avatar
FoolCrzy
Default Re: GEARING (BIG JIM 54)
He said SECOND gear...
Old Jun 18, 2003 | 07:22 PM
BAM92's Avatar
BAM92
In 2nd gear at 5700rpm you should be going 68mph.
Old Jun 18, 2003 | 07:27 PM
grumpyvette's Avatar
grumpyvette
Default Re: GEARING (BAM92)
here play with these
http://users.erols.com/srweiss/calcmph.htm
http://users.erols.com/srweiss/calcrpm.htm
http://users.erols.com/srweiss/calcrgr.htm
To GEARING
