back again/ exhaust sweet thunder
Old Jun 18, 2003 | 05:52 AM
jojolt1's Avatar
jojolt1
Default back again/ exhaust sweet thunder
Looking for any info on the chambered exhaust called sweet thunder.
Thanks again,
don :confused:
Old Jun 18, 2003 | 11:54 AM
FELNGR8's Avatar
FELNGR8
Default Re: back again/ exhaust sweet thunder (jojolt1)
I have it on my car. I love the sound, love to cruise, make er bark, all that stuff.
But I went with the 2 1/4 inch pipe at the recommendation of Sweet Thunder. Now that I have a modded motor my dyno guy tells me I need a full 3 inch custom exhaust. So I have to install something else.
With a stock motor and an LT1 you won't hurt the power with the small pipe, but I would go with the larger diameter they make. You will love running with it with the windows down. Don't expect a power gain.
That's the facts, you decide.
http://www.sweet-thunder.com
Old Jun 18, 2003 | 01:56 PM
rubyred93's Avatar
rubyred93
I have the chambered system on my car as well, and absolutely love it. Should have put it on sooner. The car has a nice rumble at idle, is aggressive/throaty under throttle and evens out to a nice rumble at cruise as well. Generally speaking, it has a good deal of "bass" tone to it. Interior noise level is increased (as you should expect), but I can still listen to the radio and hold a conversation without yelling. I don't find it annoying at all.
I could have sworn that the outer diameter of the pipes (not the inside chambered areas) were 2 3/4. The reason being, is that I did not use the clamps that came with the exhaust system, but instead purchased 2 "belt-type" clamps to secure the rear pipes to the main section. The 2 3/4 clamp was the correct size for this. Cosmetically, I felt that this made a big difference. Also, isn't the stock system 2 3/4?
I had purchased mine through Mid-America, but I no longer see it advertised for sale. Depending on the sound that you are after, this may be a system that appeals to you. It definitely has more bite to it than the stock system, but it is not obnoxious either.
Removal of the old system and installation of the new system can be done in about 3 hours. There were minimal problems with the fit, and I sealed my system in order to avoid any leaks that might have occurred.
What type of tone are you looking for? One thing that I did note is that the Corsa systems that I have heard are very quiet at idle (like factory), but the chambered system actually gives a throaty rumble at idle. :thumbs: It's a nice system, and I'd recommend it to those looking for a system with "bite" to it. :)
Old Jun 18, 2003 | 02:10 PM
FELNGR8's Avatar
FELNGR8
Default Re: back again/ exhaust sweet thunder (rubyred93)
The 2 1/4 I'm referring to is the diameter of the inner section where it's chambered. They told me the 2 1/2 would be too loud and not needed for the flow of a stock engine. But I'm no longer stock.
I really hate to give up the sound to go with something else 3". I might do some kind of compromise with the pieces they offer, instead of the catback.
If you go to their web site you will see there are a lot of choices in pipe diameter and material.
Old Jun 18, 2003 | 02:18 PM
rubyred93's Avatar
rubyred93
Default Re: back again/ exhaust sweet thunder (94lt1torchred)
Yes, I understood where the 2 1/4 diameter measurement was coming from, I was just trying to recall the factory outer diameter of the pipe. I wonder what the inner chambered diameter is/was on the systems that Mid-America was selling? Probably the 2 1/4? That's a pretty good reduction in diameter in those areas. :(
Can't blame you for not wanting to give up the sound, it's a blast to drive, as I'm sure you know. Good luck with the system that you choose/put together, and hopefully you won't lose much of the tone. :steering:
[Modified by rubyred93, 2:20 PM 6/18/2003]
To back again/ exhaust sweet thunder
