Difference between the MSD Digital 6 Plus and the MSD 6 A(L)
Old Jun 18, 2003 | 12:34 PM
Timmy!'s Avatar
Timmy!
Default Difference between the MSD Digital 6 Plus and the MSD 6 A(L)
Does anyone know what the difference is between these 2 units (in layman terms)? I am thinking about a nitrous system on my car and a lot of people are recommending the Digital 6 Plus over the MSD 6A and 6AL and I am trying to figure out exactly what it does differently - the MSD website isn't real clear... :withstupid:
Old Jun 18, 2003 | 01:05 PM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: Difference between the MSD Digital 6 Plus and the MSD 6 A(L) (Timmy!)
I'm running a TNT F1 setup and I'll let you know if/when an ignition upgrade is needed for me.
I'll be hitting the dyno Saturday (6-21-03) and don't expect any problems with the stock ignition system and NGK TR6's gapped at .038.
I do recommend an electronic TPS WOT switch and the Harlan Engineering window switch (quite a nice piece). But the stock ignition system (in good tune) should be quite sufficient for any N20 setup that can run on the street.
Old Jun 18, 2003 | 01:29 PM
scorp508's Avatar
scorp508
:skep:
To Difference between the MSD Digital 6 Plus and the MSD 6 A(L)
