setting idle speed
Old Jun 18, 2003 | 09:27 PM
6spd's Avatar
6spd
Default setting idle speed
does anyone know how to set idle speed and the iac useing the ez-link on a 91 vette what should the iac be set at i was told from tpis it should be set at 50 it doesn't seem to work any advise would be helpful thanks
Old Jun 19, 2003 | 01:16 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Default Re: setting idle speed (6spd)
yes, the IAC count needs to be around 50 with the AC off. using the software, turn the idle screw on the throttle body clockwise to increase idle so that the iac reads 50 or so. It has to be enough for the pcm to keep the set idle rpm in the program. too much, and the idle will be too high. too low and youll see the motor wants to stall when the ac is turned on.
