open end torque wrench
Old Jun 19, 2003 | 03:10 PM
CNTDRV55's Avatar
CNTDRV55
Default open end torque wrench
I searched and the last guy that asked this was not succesful in getting a good answer, so I try myself...
I am replacing a driveshaft on another car (no vette) and you CANNOT get a socket in there to torque the bolts. On something this important I would prefer to get the torque correct.
Are there open ended torque wrenches? If so, don't I need an adapter for every size? Do the shops have an entire collection? For this job I would get just the size required and add other sizes later.
Old Jun 19, 2003 | 03:19 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: open end torque wrench (tailgunner)
Use a "crows foot" attachment. It's like the end of an open ened wrench with a hole for the ratchet. This does throw off the torque reading, but there is a way to figure it out... Hopefully somebody will chime in...
Old Jun 19, 2003 | 03:24 PM
dgoodhue's Avatar
dgoodhue
Default Re: open end torque wrench (FoolCrzy)
My torque wrench came with a formula to calculated with the crow feet. Your basically doing a ratio of the new length/old length and multiplying it by the toque reading.
Old Jun 20, 2003 | 05:26 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
:confused: :confused: :confused: :confused:
Old Jun 20, 2003 | 06:40 AM
Darkness's Avatar
Darkness
Default Re: open end torque wrench (oldace84)
[Modified by Darkness, 3:40 AM 6/20/2003]
[Modified by Mr Mojo, 8:12 AM 6/20/2003]
Old Jun 20, 2003 | 08:48 AM
jfb's Avatar
jfb
A crowfoot wrench has so little distance between the nut center and the center of the square for the torque wrench, that the slight increase in the moment arm is insignificant and the error is "lost" in the inaccuracy of the torque calibration of the torque wrench. I wouldn't worry about it because the actual applied torque to the nut is increased very little.
Old Jun 20, 2003 | 10:03 AM
ROADAPPLE's Avatar
ROADAPPLE
Default Re: open end torque wrench (jfb)
Crowsfeet are used in aircraft rebuild/repair quite often. I do not use any formula, the normal torque setting is "close enough". Think about that the next time you climb into an airplane! :D
Have a great week-end,
Old Jun 20, 2003 | 10:12 AM
ittlfly's Avatar
ittlfly
Default Re: open end torque wrench (C44ever)
Have a great week-end,[/QUOTE]
Now that's a comforting thought. :jester
[Modified by ittlfly, 7:12 AM 6/20/2003]
Old Jun 20, 2003 | 11:48 AM
Southern Comfort's Avatar
Southern Comfort
Default Re: open end torque wrench (ittlfly)
I was an aircraft mech for quite some time and the crows foot is the only way to touque tubing nuts. Of course I had to be the one to torque the "wing nuts" that flew the damn things. :rofl:
Old Jun 20, 2003 | 02:22 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Check this link out for torque wrench options.
http://www.mcmaster.com/
Go to page 2617.
~ Purp
Old Jun 26, 2003 | 06:45 PM
CNTDRV55's Avatar
CNTDRV55
Default Re: open end torque wrench (PurpleC4)
Go to page 2617.
~ Purp
Thanks. Thats what I was looking for. But geeeez... ~$100. Then ~40 bucks per adapter/size! :eek:
Old Jun 26, 2003 | 06:59 PM
Gary04Z06's Avatar
Gary04Z06
How about this one on a regulat torque wrench:
http://buy1.snapon.com/catalog/pro_d...re&dir=catalog
[Modified by Gary96LT4, 5:59 PM 6/26/2003]
Old Jun 26, 2003 | 08:08 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Tailgunner ~ I agree, the price is steep. I just wanted to show you where you could get one. A simple crows foot on an existing torque wrench should be sufficient.
:yesnod:
~ Purp
Old Jun 26, 2003 | 08:12 PM
froggy47's Avatar
froggy47
For occasional use, get a cheap set at Harbor Freight.
Old Jun 27, 2003 | 09:32 AM
CNTDRV55's Avatar
CNTDRV55
:yesnod:
~ Purp
Yeah I know, thx. :thumbs: I guess since this is the first time I have even thought about needing one, I'll get the crows foot (unless HF's set is cheap enough) and go from there.
To open end torque wrench
