Spicer halfshaft U-joints
Old Jun 21, 2003 | 02:47 AM
smar's Avatar
smar
Default Spicer halfshaft U-joints
I am about to replace them as a part of preventative maintenance. Old ones are Spicer no grease nipple. Does anybody have a better sugestion, if not I'll go with the same ones.
Old Jun 21, 2003 | 03:29 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Spicer halfshaft U-joints (smar)
Those r prefered by many! They're made by Dana I belive. Where is ur source? & what year car & tranny type?
:cool:
[Modified by edsalinas, 1:30 AM 6/21/2003]
Old Jun 21, 2003 | 05:03 AM
smar's Avatar
smar
Default Re: Spicer halfshaft U-joints (edsalinas)
Thx for reply
it is 85 4+3, 8.5" rear, DOT tires, upped 350 (cracked one transmission case already, dont want to see shaft whipping)
Old Jun 21, 2003 | 12:30 PM
1MoorTym's Avatar
1MoorTym
Nope, there's none better. Spicer are made by Dana.
Old Jun 21, 2003 | 12:41 PM
MrCrowley's Avatar
MrCrowley
I can sell you a brand new set of spicer ujoints with a cryo-ing treatment. Which makes them ever stronger.
Old Jun 21, 2003 | 03:54 PM
edsalinas's Avatar
edsalinas
Default Re: Spicer halfshaft U-joints (MrCrowley)
Doesn't it also make them brittle? when I worked at the U of A, when ever someone lost the keys, or combo, to the lock on their bike, we'd submerge the lock in liquid nitrogen for about 5 minutes, then hit the lock with a hammer, it would shatter into a million pieces ? ? ? ? ?
:D
[Modified by edsalinas, 1:56 PM 6/21/2003]
Old Jun 21, 2003 | 04:27 PM
smar's Avatar
smar
Too late got set of four this morning, Spicer 5-447X
Old Jun 21, 2003 | 06:48 PM
edsalinas's Avatar
edsalinas
ttt
Old Jun 21, 2003 | 07:07 PM
smar's Avatar
smar
:D
I believe the cryogenic treatments is done only to the rolling surfaces to harden it (sort of tempering), the core of metal is not affected. :confused:
Old Jun 21, 2003 | 07:12 PM
scorp508's Avatar
scorp508
The cold forged spicers are majorly strong, no issues there. :)
Old Jun 21, 2003 | 07:13 PM
mash557's Avatar
mash557
I imagine if you smacked the U-joints with a hammer just after they came out of the cryogenic liquid, they would also shatter. Cryo treating cools the parts to extreme temps, then warms them in a controlled manner. Once warmed again, brittleness should be gone.
Old Jun 21, 2003 | 07:32 PM
LD85's Avatar
LD85
Default Re: Spicer halfshaft U-joints (mash557)
You know I always saw the bearings and caps go, at least thats what happened on mine, never saw the cross piece/body broken, anyone else se the body broken? :confused:
Old Jun 21, 2003 | 08:37 PM
smar's Avatar
smar
Default Re: Spicer halfshaft U-joints (ld85)
I found this tread informative http://forums.corvetteforum.com/zerothread?id=572508
[Modified by smar, 12:03 PM 6/22/2003]
To Spicer halfshaft U-joints
