adjust the knock censor..
Old Jun 22, 2003 | 05:54 PM
devilfish's Avatar
devilfish
Default adjust the knock censor..
where do i set how sensetive the knock censor is going to be? Can it be done??
Old Jun 23, 2003 | 05:31 AM
Davemc1963-87conv's Avatar
Davemc1963-87conv
Default Re: adjust the knock censor.. (devilfish)
I believe one way to de-sesitise the knock sensor is to use Teflon (PTFE) thread tape on the threads when screwing it into the block, however I have no personal experience of this.
Maybe someone else can comment?? :D :steering:
[Modified by Davemc1963-87conv, 10:33 AM 6/23/2003]
Old Jun 23, 2003 | 11:40 AM
Aaron's 87's Avatar
Aaron's 87
Default Re: adjust the knock censor.. (Davemc1963-87conv)
How much install torque you use supposedly also has an effect.
Old Jun 23, 2003 | 05:42 PM
devilfish's Avatar
devilfish
Default Re: adjust the knock censor.. (Aaron's 87)
hmm
after my 1,6rrsm headers, no cat etc etc. I pick upp false knocks at cruise speed. When I floor it no knocks..
Old Jun 24, 2003 | 10:31 AM
Aaron's 87's Avatar
Aaron's 87
How do you know they're false knocks?
Noisy valvetrains and rooler chains MAY sound like knocks to your KS
Old Jun 24, 2003 | 05:11 PM
devilfish's Avatar
devilfish
well im also getting knock counts @ 1500 rpm with 0% throttle. That's should be valvetrain noise. Im are also losing 6 degrees of timing due to this. My knock counts are also linear and don't change under load.
A sure sign of mechanical noise.
Old Jul 1, 2003 | 11:18 PM
kbklt1's Avatar
kbklt1
Try this page and look at the Knock circuit he has used.
Never tried it, no false knock here, but it sounds good on paper
http://www.charm.net/~mchaney/f-tech.htm
If you do it let us know how it works out...
Old Aug 1, 2003 | 02:27 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
The EASIEST and the CHEAPEST way is to adjust your ECM's "Knock Attack" table and the "Knock Decay" tables on your EPROM.
The tables are set up with attack and decay rate values for different RPM ranges.
GM is pretty aggressive with their Knock Attack rate and pretty slow to bring in the Knock Decay or reduction in timing retard after knock is detected.
You can adjust the mutliplier to reduce the effect of knock sensing at the RPM you need to do this.
After you "desensitize" the knock attack rate you can go to the Knock Decay table and sensitize it to pull the knock retard back out faster after knock is detected.
I had a VERY pesky knock detection at around 2000-2200 RPM that put a big hole in my acceleration that I could feel in my SOP indicator.
After determing it wasn't real knock and only some engine noise picked up by the KS I performed the above procedure and have been smiling ever since.
I'm sure I didn't invent this procedure but no one told me about it so as always, YMMV.
[Modified by VetNutJim, 1:28 PM 8/1/2003]
Old Aug 19, 2003 | 04:15 PM
DieL's Avatar
DieL
Default Re: adjust the knock censor.. (VetNutJim)
very interesting, but can this be done on a 93??
To adjust the knock censor..
