Speedometer recalibration...
Old Jun 22, 2003 | 11:34 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Default Speedometer recalibration...
Anyone know where to order the speedometer recalibration gear. I'm switching from 2.73 to 3.54. Thanks in advance...
Old Jun 23, 2003 | 09:04 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Default Re: Speedometer recalibration... (Blueyednd)
Hello, is this thing on?
Old Jun 23, 2003 | 09:05 PM
smar's Avatar
smar
I believe that 1984 and up Speedometer recalibration is done in ECU.
Old Jun 23, 2003 | 09:35 PM
CFI-EFI's Avatar
CFI-EFI
You asked this same question on 6/18 @ 11:03 PM. I responded less than 24 hours later, on 6/19 @ 8:40 PM. Was there something lacking in my response? For review, here is my post:
You should currently have a 8640517, red, 17 tooth, drive gear, a 25513044, red, 37 tooth driven gear, and a 25007338 sensor. You will need a 8642620, gray, 15 tooth, drive gear, a 25513049, green, 42 tooth, driven gear, and a 25007339 sensor. Even needing all three items, this is much more sanitary, and less expensive than the "black box" correcter. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
I guess I didn't mention that these are GM part numbers, available from your favorite GM dealer. The numbers come from an older book. Any numbers not still current should supercede. I hope I'm not too late, THIS time.
RACE ON!!!
1984 Crossfire
Member NHRA
Old Jun 23, 2003 | 10:51 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Default Re: Speedometer recalibration... (CFI-EFI)
Nothing lacking. Thanks a bunch. Sorry I missed your post somehow. I'm getting anxious because my new diff is due to arrive any day I want to have all parts here and ready to go.
I have searched the net over and over again to try to find part numbers and you did it in one, ok, two trys. :D Thanks again. :thumbs:
Old Jun 24, 2003 | 11:00 PM
CFI-EFI's Avatar
CFI-EFI
The second post wasn"t a "try". I merely cut and pasted, my origional post. It was enough work, that I wanted to make sure you benefitted from it. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
Old Jun 25, 2003 | 05:07 PM
93 ragtop's Avatar
93 ragtop
Not meaning to butt in on this post, but could you tell me what I need for a 4.09 gear? I had the 2.59 and I switched to a 3.54, got the 15tooth inside gear, the new sensor, and the driven gear, so I hope I can get by with just the driven gear. Thanks in advance.
Old Jun 27, 2003 | 05:55 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Default Re: Speedometer recalibration... (93 ragtop)
93 Ragtop - When I called my local Chevy dealer, they looked the parts up for me because the part numbers listed were different than listed above, based on 17" wheels vs 16" factory wheels, etc. The Chevy parts shop was very helpful getting the correct parts ordered. I don't know about the sensor. I was told I would have to have it ($90). The gears were only $5 each. Good luck.
Old Jun 28, 2003 | 05:48 AM
93 ragtop's Avatar
93 ragtop
Thats high. When I did my 3.54 a couple of years ago, I paid $40.00 + for the 2 gears and the sensor. I got it through Jeff Koop at Superior Chevrolet. But I understand he is no longer with them. I used to see him on this forum a lot, but havnt noticed anything lately.
Old Jun 28, 2003 | 01:29 PM
CFI-EFI's Avatar
CFI-EFI
If you wanted them for 17" wheels...Why didn't you say so??? Only the driven gear would change, and probably by only one tooth. They don't list different gears for your origional ratio for different tire sizes. I made an assumption based on YOUR lack of input. I also gave you the sensor information. I must not be believable. First, ignored then, second guessed. I enjoy helping people on this forum that need and want help. You seemed to require neither. Why did you Ask??? :mad RACE OFF!!!
Old Jun 28, 2003 | 11:41 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
What is your deal? Lighten up... I apologized for not seeing your original post and then poked fun at myself for having to do it twice. I thanked you for the information. I printed out your post and took it to the Chevy dealer and gave them the numbers. They asked me more questions, such as the wheel size. I didn't know that it mattered, so the numbers you gave me were not exact for my application, but I used your info to get the correct stuff. You weren't ignored or second guessed and I don't know why you've taken this so personally. 93 ragtop asked a questions and I told him what I did. Sorry if this makes you :mad . I thought this was the place to ask questions. I appreciated your info because I had no idea what parts to get or where to get them. I don't understand why my questions or description of ordering the speedo gear has caused you to have such heartburn. Thanks again for the info and my best to you.
Old Jun 29, 2003 | 02:14 PM
CFI-EFI's Avatar
CFI-EFI
At yourself???
"and you did it in one, ok, two trys."
You have me making "two trys"
...so the numbers you gave me were not exact for my application,
As exact as the information you provided.
I answered the origional question within 24 hours of the post. AFTER I answered, you, reposted and reasked the same question...Ignoring my answer.
It was a moderate amount of work, which I was happy to do for a forum member in need.
Questions, you really want/need the answers to.
It wasn't the question or the ordering. It was the treatment of, and the value you attributed to my answer...BOTH times. Possibly, before you ask another question, you will consider if you really, NEED the answer. I guess, it's really myown fault. I just should have said, "Call Chevy". Or better yet, nothing at all.
Old Jun 29, 2003 | 02:28 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Jeff has moved up, but he is still there. His replacement (Chris) is very helpfull also. :steering:
Old Jun 29, 2003 | 02:40 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Speedometer recalibration... (Ramrod92)
The last time I called Superior Chevrolet, Jeff was in management prep meetings. I believe he has been made the parts manager. Congratulations, Jeff, and thanks again for all your prior help (future, too).
RACE ON!!!
1984 Crossfire
Member NHRA
Old Jun 29, 2003 | 03:37 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
I'm not spending any more time in trying to explain after this. Please forgive me for not giving more "value" to your answer. I thought that printing out your reply and taking it directly to Chevy was giving you 100% credit. Also forgive me for trying to make a "funny" with the "two trys" joke, it was not intended to be a reflection of you. Again, I wouldn't have asked the question again if I had seen your original post. I don't ask questions that I don't need answers to like I have seen here before like "how fast will an 89 vette go?" See, that was a joke if you read that post and the other 3 that matched it from last week posted by the same guy. Thanks again for you most valuable information and work to help out a forum member. Because of you, I got the parts I needed. THANKS, THANKS, THANKS, now relax.
[Modified by Blueyednd, 2:38 PM 6/29/2003]
To Speedometer recalibration...
