Another O2 sensor question
Old Jun 24, 2003 | 04:40 PM
Thumper's Avatar
Thumper
Cruise-In II Veteran
Default Another O2 sensor question
I know that '95's come with 3 O2 sensors but the computer only reads 2 of them, 1 on each side. On the passengers side which one is real, the one in the front or the back? :confused:
Old Jun 24, 2003 | 06:33 PM
superlund's Avatar
superlund
Default Re: Another O2 sensor question (Thumper)
The front sensor is the primary...I had my rear sensor unhooked w/o issue. I also was running Datamaster at the time so I could monitor the BLM's Etc. so I know the volts were coming from the front sensor. Never even set a code w/o the rear sensor.
Old Jun 24, 2003 | 08:06 PM
Lone Ranger's Avatar
Lone Ranger
The rear sensor just monitors the cat I believe. The two fronts are the oens that the ecm listens to for air/fuel mixture decisions.
Old Jun 24, 2003 | 11:13 PM
Thumper's Avatar
Thumper
Default Re: Another O2 sensor question (Lone Ranger)
Thanks. That's what I thought but I wanted to confirm it. Hopefully now I can fix that check engine light. :chevy
Old Jun 25, 2003 | 09:01 AM
ZZZASY's Avatar
ZZZASY
Remember to check the O2 sensor fuse. After replacing my sensors the light kept coming back on. That's when I looked in the book and realized that there was a fuse for the sensor. Checked the fuse; it was blown; replaced it everythings ok.
ZZZASY
'94 LT4
Old Jun 25, 2003 | 09:41 AM
ZylaRace's Avatar
ZylaRace
Default Re: Another O2 sensor question (ZZZASY)
As stated the front sensors are what the PCM uses to tune the fuel. The rear sensor is to monitor the CAT performance. It is an OBD2 thing. The 95 is an OBD2 wanna be, so I'm not sure what it does w/ that signal.
I doubt disconnectiong it will solver your "check" light problems.
Old Jun 25, 2003 | 01:04 PM
Thumper's Avatar
Thumper
All this time and the fuse was blown, good call. Often times it is the little things. I changed the fuse and it still tripped the check engine light. I need to re-set the codes tonight and try again.
To Another O2 sensor question
