Headlight problem with '89
Old Jun 25, 2003 | 10:50 AM
Black'69's Avatar
Black'69
Default Headlight problem with '89
The headlights on the car seem to be having a hard time raising up. You can help them a long by lifting them up and they will work, but sometimes will fall back down. I heard that there are some bushings that can be replaced to fix the problem. Is this correct? Has anyone attempted this fix? Any tips?
Christ
Old Jun 25, 2003 | 12:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Headlight problem with '89 (Black'69)
It sounds like the three Durelin bushings in the motor case are powder.
You can order them from MAD for a few $$.
Remove the motor & headlight assembly from the car and take the motor & gear case off the headlight frame. I needed a ball driver to remove several Torx bolts.
You may need to work a little to get the main gear off the worm gear as there is a ridge on the main gear but it will come.
Old Jun 25, 2003 | 12:48 PM
Black'69's Avatar
Black'69
Default Re: Headlight problem with '89 (65Z01)
That doesn't sound too bad, the bushings are pretty cheap, beats replacing the whole motor for $230.
Thanks!
~C~
Old Jun 25, 2003 | 02:25 PM
1989redvette's Avatar
1989redvette
mine did exactly the same as yours when i bought it ..... i bought mine through ecklers they are three little nylon bushings that replace the jelly that is in there... i follwed the instructions and i think it took about an hour a piece to do the mod... :D big big difference and still working great after 3 years :cheers:
To Headlight problem with '89
