iac question /again
Old Jun 26, 2003 | 03:16 PM
Frank92's Avatar
Frank92
Default iac question /again
i cleaned the iac and did a reset. the car idles perfect, but after i drive and stop the first time, it idles to low. it seems that the iac relearns wrong ?
frank :confused:
Old Jun 26, 2003 | 11:00 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Default Re: iac question /again (Frank92)
the entire iac unit may need replacing..just a thought
Old Jun 26, 2003 | 11:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: iac question /again (eamador11)
I tend to agree; assuming the connections are good and the bore is clean the unit should be replaced.
First check that you have no vacuum leaks.
Old Jun 26, 2003 | 11:41 PM
lspalding's Avatar
lspalding
I would be suspicious of tb issues (worn shaft). However, if you want to try another IAC, I'll sell you a used one I know is working properly if you can't get one over there (off my '95, I think it's the same). lspalding@ameritech.net
Old Jun 27, 2003 | 01:20 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default Re: iac question /again (lspalding)
I started to get the IAC code when I use the AC and stop at a light. the RPMs drop to 500 or below, and bang light comes on. How hard is it to replace the IAC?
Old Jun 27, 2003 | 08:13 AM
Frank92's Avatar
Frank92
Default Re: iac question /again (Bluewasp)
thanks for response. i already have a new (1/2 y.o.) iac valve. i cleaned the intake yesterday but no change.
i remeber taht i took off the thin vacuum lines (under left cover) to reach the oil presuure switch (i changed the switch). from this moment she had the symtoms (rough idle). maybe i bent the map a litlle bit, so that maybe the small thing that goes into the left engine side is not sitting right in the middle (and stuck).
i´ll check these vacuum related things today and see what happens.
thanks frank
p.s. i hope i can visit the "great 50 years corvette meet" tomorrow in munich (germany)
Old Jun 27, 2003 | 01:59 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
The best way to do this is to remove the throttel body and remove the IAC and than get some throttel body cleaner and clean the assembly out taking care not to wet the TPS. You be suprised how varnished the area around the blades are.
Old Jun 27, 2003 | 02:07 PM
65Z01's Avatar
65Z01
Bluewasp, to change the IAC you just:
-unplug the cable & unscrew the IAC
-clean the pintel bore with carb cleaner
-install the new IAC & plug in the cable
-set base idle, per method on my site
Old Jun 27, 2003 | 02:33 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
frank :confused:
Frank92,
The IAC doesn't learn anything. Its just set wrong.
Search through the archieves on IAC and my user name you will find a few of the articles I wrote that explain the idle problems that people have. Its way to much to retype.
That is why I wish we had sticky posts. hint hint.
To iac question /again
