2-bar map sensor Part number?
Old Jun 27, 2003 | 12:40 PM
Ronnie_W's Avatar
Ronnie_W
Default 2-bar map sensor Part number?
Anyone know the number of the 2 bar that will work with my LT1.
Old Jun 27, 2003 | 12:51 PM
krivera's Avatar
krivera
Default Re: 2-bar map sensor Part number? (Ronnie_W)
:nonod:
Old Jun 27, 2003 | 12:59 PM
dgoodhue's Avatar
dgoodhue
You can't plug a 2 bar map sensor into your ECM and have it work. The stock map sensor outputs a signal that is from 0 - 5 volts, 0 psi is 5 volts, on a 2 bar map 0 psi is 2.5 volts. You could scale the tables in the ECM to account for the map sensor, but this is not for a novice. This is a lot of work because you have modify a good portion of the table because they use the map or load for a lot of calculations.
BTW The Gm part number for a 2 bar map is 16009886
Old Jun 27, 2003 | 03:16 PM
Ronnie_W's Avatar
Ronnie_W
Default Re: 2-bar map sensor Part number? (dgoodhue)
I have a speedpro (now FAST) computer. I can choose 1,2 or 3 bar maps. Thanks for the part number?
[Modified by Ronnie_W, 2:17 PM 6/27/2003]
To 2-bar map sensor Part number?
