92 A/C recharge questions (technical)
Old Jun 28, 2003 | 05:46 PM
ANTI VENOM's Avatar
ANTI VENOM
Default 92 A/C recharge questions (technical)
I took the 92 down to have the A/C filled. It was low and the "tech" filled it up. He then told me that something was wrong with my low pressure switch. He took their freon back out and sent me on my way. I jumpered the low pressure sw. out and the a/c compressor still would not come on. I checked the climate control codes and there was still an 09. (low freon) I disconnected the battery and then hooked it up with the jumper still on the switch. I tried the A/C and the compressor clutch pulled right in. My question is, doesn't the code go away when the pressure is normal? Does it have to be cleared when the A/C is serviced? If this is so, why didn't the "techs" know this? :nonod:
Old Jun 28, 2003 | 05:56 PM
SPEED750's Avatar
SPEED750
Default Re: 92 A/C recharge questions (ANTI VENOM)
I think once a code is trip'd you have to clear it out like you did.Maybe the tech didn't think about the code and just wrote it off as the switch.If you jumped it and it worked, I would replace the switch and go back for a recharge.GOOD LUCK. :chevy
