85 w/4+3 Question
Old Jun 28, 2003 | 09:30 PM
Vette Head's Avatar
Vette Head
Default 85 w/4+3 Question
Well, I changed the fluid in my OD unit, and while I'm really glad I did it, I have some general questions about the OD.
When engaging the OD, should I: a) let off the gas, b) depress the clutch, c) engaged between gears, or d) at anytime
When the OD engages, it is a very noticeable engagement. It makes the car somewhat jerk. I'm not talking about the kickdown, but the change over from regular 4 speed to 4+3.
With the OD engaged in town, and starting from a stop or low speed, when I go into 2nd, there is a jerky like feeling. I doubt this is normal, but I figured I should check.
How can I improve the driveability of my OD? I just think it should be a much smoother transition. Do you guys drive around town with just the 4speed, and hit the OD when entering te freeway, or what?
And lastly, I plan ontaking her to runs 1/4s next weekend. For best times should I use the OD, or just run the 4?
Thanks all!
Kirk :seeya
Old Jun 28, 2003 | 09:49 PM
scorp508's Avatar
scorp508
Default Re: 85 w/4+3 Question (kirks518)
I use the clutch unless I am at full throttle as it is smoother and will take a big load off of the O/D unit and make it last longer.
I typically don't use O/D in town, only on the highway.
If you go into 2nd at low throttle the computer engages O/D to help save on gas (early version of CAGS like on the 6-speeds later). It can be kinda clunky if you're going slow.
Old Jun 28, 2003 | 09:56 PM
87Beast's Avatar
87Beast
Sounds like your OD runs just like mine. When I kick out of the OD I press the clutch so it doesn't buck as hard.
Also watch for the black 87 around town
Old Jun 28, 2003 | 11:06 PM
LD85's Avatar
LD85
Default Re: 85 w/4+3 Question (87Beast)
Ditto, I use the clutch otherwise it will "jerk" just litke yours , alo I ony use it on the interstate at crusign speeds, not in the city
To 85 w/4+3 Question
