header plug number?
Old Jun 30, 2003 | 05:55 PM
Rays91L98's Avatar
Rays91L98
Default header plug number?
I just installed hooker super Comp Headers on my 91 L98 and it looks like two plugs are going to be very close. Can someone please give me a brand and part number for the shorter head plugs for use with headers? I usually use rapid fire 5's.
Thanks for the info
:seeya
Old Jun 30, 2003 | 06:00 PM
cyclerage23's Avatar
cyclerage23
Default Re: header plug number? (Rays91L98)
I dont think they make the header plugs to fit the l98 aluminum heads, I just went through the same nightmare
Old Jun 30, 2003 | 06:32 PM
Terry@TPiS's Avatar
Terry@TPiS
There are no "short" plugs for this application. Accell has a part number, but it is a shorter reach inside the head, and regular length outside the head.
Which will not make a difference.
You will have to dent the headers to clear the plugs.
Old Jun 30, 2003 | 07:01 PM
MrNuke's Avatar
MrNuke
Default Re: header plug number? (Terry@TPiS)
I thought Accel's Header Sparkplugs' are made standard length inside and shorter on the outside..I compared them in the store a few weeks ago befor eI was putting my LPE longtubes on the car as I was told I might need them, and they were defenately shorter on the outside..
Godo thing is I didn't need them. Still using normal plugs.
Old Jun 30, 2003 | 07:04 PM
scorp508's Avatar
scorp508
Default Re: header plug number? (MrNuke)
I have a set of hooker 2149s and my rapidfire #5s go in and out without a single problem. In fact its way easier than with the stock manifolds!
Old Jun 30, 2003 | 09:28 PM
1MoorTym's Avatar
1MoorTym
Default Re: header plug number? (scorp508)
:iagree: Clearance is excellent with these headers, I was pleasantly surprised.
Old Jun 30, 2003 | 10:05 PM
Rays91L98's Avatar
Rays91L98
Default Re: header plug number? (1MoorTym)
Driver side is OK, Just looked like some on the passenger side were way to close, they might go in but the wires will surely melt. Again, any part #'s, brands?
Old Jun 30, 2003 | 10:46 PM
LD85's Avatar
LD85
Just came from the speed shop tonight no stubbys for the L98 engine!
My #4 & #5 are close too!
Old Jul 1, 2003 | 08:33 AM
cyclerage23
Default Re: header plug number? (ld85)
Right now I still have the AFR staight plugs and Hooker super comps and my cylinders 2 and 5 are so close that I have to chaange the boot every few days. Thats after denting the tubes.
To header plug number?
