427 is in
Old Jun 30, 2003 | 08:31 PM
DiabolicalDave's Avatar
DiabolicalDave
Default 427 is in
The 427 and ZF 6-speed are installed. Aside from just bolting-up and wiring-up things, I’ve got to sort-out custom fuel lines, custom clutch line, custom water neck, and wiring up the new distributor and external coil. ETA is 2 or 3 weeks out. :steering:
Old Jun 30, 2003 | 08:58 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: 427 is in (DiabolicalDave)
OMG!!! That's CRZY!!!
I love it!
:cheers:
Old Jun 30, 2003 | 09:01 PM
Dark-Knight's Avatar
Dark-Knight
DD. way, way :cool: !!!!!!!!!!!!!!
Old Jun 30, 2003 | 09:08 PM
CFI-EFI's Avatar
CFI-EFI
Way COOL!!! A man after my own heart. Love those valve covers. How'd you do that? Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
Old Jun 30, 2003 | 09:43 PM
J Z06's Avatar
J Z06
Default 427 is in
Best of luck with it. If it's anything like my friends 434 18* headed motor, it'll be nutty!
Old Jun 30, 2003 | 09:53 PM
LD85's Avatar
LD85
Default Re: 427 is in (Jay D 90 383)
DD, check your oil pan kick out if you have one. To get mine off I have to remove the engine mounts and lift the engine @ 1-2 inches. I trimmed my motor mount bolt length so that the nut faces the back of the engine and the bolt can be pulled out from the front,,, otherwise the bolt will hit the header if you try to pull the bolt towards the rear! Then you will have to loosen the headers t oget teh bolt out.
I hope this does not matter on your setup but if it does,, do it now cause later will be a PITA, I figuried this out on pull #2!
And BTW AWESOME! :hurray: :hurray: :hurray: :smash:
[Modified by ld85, 9:54 PM 6/30/2003]
Old Jun 30, 2003 | 10:38 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: 427 is in (ld85)
:cool: :cheers:
Old Jun 30, 2003 | 11:31 PM
BAM92's Avatar
BAM92
427 :cool:
Old Jun 30, 2003 | 11:34 PM
Vette9d1's Avatar
Vette9d1
Default Re: 427 is in (BAM92)
Very sweet! Is it a small block or the big block? It looks like a stealth ram on there. Tell us how she pulls. :cool:
Old Jun 30, 2003 | 11:37 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
:cool: :cheers: :thumbs:
Old Jun 30, 2003 | 11:49 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In V Veteran
Very :cool: indeed!
A man after my own heart. There IS no replacement for displacement! :steering:
[Modified by MagikDraggin, 11:24 PM 6/30/2003]
Old Jun 30, 2003 | 11:51 PM
ROME's Avatar
ROME
What type of induction are you using?
:eek: :thumbs: :lurk:
Old Jul 1, 2003 | 12:00 AM
atotalnincompoop's Avatar
atotalnincompoop
:thumbs:
Old Jul 1, 2003 | 12:28 AM
thetoy's Avatar
thetoy
Default Re: 427 is in (atotalnincompoop)
:cool:
Old Jul 1, 2003 | 02:43 AM
bill mcdonald's Avatar
bill mcdonald
Default Re: 427 is in (thetoy)
:thumbs:
Dying to see the stealth ram mounted!
Old Jul 1, 2003 | 02:56 AM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Thats amazing..Gotta love every inch... :party:
Old Jul 1, 2003 | 05:52 AM
Darkness's Avatar
Darkness
Default Re: (2nd2SEX)
DAYUUUUUUUM, that is the shnizzle ma nizzle man, that is way :cool: :smash: :smash: :smash:
To 427 is in
Old Jul 1, 2003 | 08:24 AM
DiabolicalDave
Default Re: 427 is in (MagikDraggin)
CFI-EFI - valve covers done by "Unique Accessories". They do custom valve cover engraving. I am real pleased with their work.
Vette9d1 - it's a small-block - basically a stroked 400; 4.00" stroke, 4.125" bore
Magik Draggin - you are correct sir. My plates will read "CUBES"
ROME - It's the stealthram. I'm using a custom plenum that will clear the hood.
Thanks for the :thumbs: My next post on this should be when it's running and hopefully that post contains a lot of explitives because I'm so stoked over how it runs. :D
Old Jul 1, 2003 | 08:36 AM
SharkB4C4's Avatar
SharkB4C4
:cool:
Old Jul 1, 2003 | 11:39 AM
RM 4 TWO's Avatar
RM 4 TWO
SWEET!!!! :thumbs: :thumbs: :thumbs:
