C Beam question
Old Jun 30, 2003 | 10:43 PM
GRX's Avatar
GRX
Default C Beam question
What is the original intention of the C Beam (besides an installation nightmare). Why didn't GM employ a trditional tranny crossmember and rubber mount? I know I read about it years ago but can't remember why.
Old Jul 1, 2003 | 06:13 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: C Beam question (GRX)
I think rigidity is behind the engineering.
Perhaps ease of assembly on the line (I said on the line, not at home) had a hand in it as well.
It's not that bad if you get some "gear wrench" stubbies to work on top of the C-bar. Better yet, pick up some "C-bar clamps", I may be calling them by the wrong name, I have there web site at work. They're like nut plates that you install on top, they replace the hex nuts, then you only rachet the bolt in from the bottom.
They're called C-beam plates, here's the web site.
http://www.zfdoc.com/c4beamplate.htm
[Modified by edsalinas, 6:37 AM 7/1/2003]
Old Jul 1, 2003 | 06:27 AM
Rich B.'s Avatar
Rich B.
The "C" beam is there to keep the bugs out of your eyes... :D
Old Jul 1, 2003 | 09:27 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: C Beam question (Rich B.)
Its really to keep the rear from moving front to back and also to assist in it not twisting. If you look at the way the rears are help in there. There is no front to back support, other than the C beam.
Its not that hard to install. You just have to be able to manipulate the tranny up and down to get the c-beam on.
Old Jul 1, 2003 | 09:32 AM
scorp508's Avatar
scorp508
Default Re: C Beam question (ski_dwn_it)
Once you've done it a couple of times you'll be surprised how easy it is to get in and out.
Old Jul 1, 2003 | 10:44 AM
GRX's Avatar
GRX
Default Re: C Beam question (scorp508)
I've done it more times than I want to remember :D Its always a pain in the butt.
Old Jul 1, 2003 | 08:12 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
My first time was a PITA!(that is, removing the C-Beam :lol: :lol: )....I was dreading putting it back on...but not a problem...now I feel like a pro.
Old Jul 1, 2003 | 08:50 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: C Beam question (Bruthish)
I had no trouble getting my c-beam in n out the second time around. The nuts and bolts are all easily accessible on my '85
The c-beam takes up engine torque so the rest of the chassis doesn't have to.
To C Beam question
