Destroyed IAT sensor HELP!
Old Jul 1, 2003 | 11:25 AM
vvv90's Avatar
vvv90
Default Destroyed IAT sensor HELP!
while trying to follow ATI's "Instructions" I ruined the element. I know I have to buy another but I don't want to destroy the new one too.
What is the proper way to remove this? Is there some aftermarket one I can use instead? HELP! :cry
Old Jul 1, 2003 | 12:31 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Destroyed IAT sensor HELP! (vvv90)
Are you talking about the air temp thing-a-ma-bob that's in the intake hose between the TB and air filter? If so buy a new one that comes with the relocation kit and move it down to the air filter.
Old Jul 1, 2003 | 02:14 PM
vvv90's Avatar
vvv90
Default Re: Destroyed IAT sensor HELP! (fsr402)
Yes,
I will check into the relocation kit. The problem is the blower. Air is pressurized at the IAT so I can't just simply cut a hole in the rubber and stick it in. I need to remove the element and put it into a plastic tube that seals onto a bung onto the intake like so:
Old Jul 1, 2003 | 02:25 PM
krivera's Avatar
krivera
:iagree:
But should i do that to mine!
Old Jul 1, 2003 | 05:30 PM
vvv90's Avatar
vvv90
Default Re: Destroyed IAT sensor HELP! (krivera)
I've decided to try again, I ordered 2 IAT sensors from Superior chevy. They are plastic instead of brass like the stock one so hopefully I can get the element out.
they were only $10 a piece too. I hope they're the right parts.
Kevin, I would keep the IAT after the intercooler. That's going to be the most reliable temp of the intake air.
Old Jul 1, 2003 | 10:53 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
Ok now I am confused, why would you want to take the element out?
Old Jul 2, 2003 | 11:01 AM
vvv90's Avatar
vvv90
Because the standard fitting just slides into the intake tube. Since I'm running a supercharger I need a better seal. Therefore, I need to take the element out and put it into a different fitting that screws into a bung on my aluminum intake tube. See picture above.
:cheers:
Old Jul 5, 2003 | 10:49 AM
Bruce's Avatar
Bruce
This is how I have mine done. 1st I use a hand held cut off tool to carefully cut out the plastic housing and carefully get it out. To put it back into the new housing that ATI supply, it won't fit right. So I have to using Super Clued, it works wonder for me. Good luck.
PS also the IAT wires are not long enough to reach it. You will need to make an extension wires.
Bruce
Cogged drive is in the work
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stage II heads
[Modified by Bruce, 9:51 AM 7/5/2003]
To Destroyed IAT sensor HELP!
