Diacom with 1988 TPI
Old Jul 2, 2003 | 11:28 PM
Chatman's Avatar
Chatman
Default Diacom with 1988 TPI
Folks, I've racked by brain. I've tried every combination of adapter (1982 and up and TPI), mode (diagnostic and normal) and rate (normal and fast). I get next to nothing. There is a response from the car (idle speeds up or I get flashing check engine with diagnostic mode) but I don't get all the cool info.
I'm running from a harddrive, Dell Lattitude, Windows95, shut off and restart in DOS. I also do the sequence by the book. Any help would be most appreciated.
Old Jul 2, 2003 | 11:32 PM
severe-1's Avatar
severe-1
Default Re: Diacom with 1988 TPI (Chatman)
I have to use a "/F" command with my 86. Have you tried that?
Old Jul 2, 2003 | 11:54 PM
Chatman's Avatar
Chatman
Yes. Just got back from the garage. With the TPI attachment I do get idle advance in normal mode and Service Engine Soon flashing in diagnostic mode. Which connector are you using?
Old Jul 3, 2003 | 12:25 AM
severe-1's Avatar
severe-1
I use the "special" adaptor in normal mode. I beleive you use the 82 up in diagnosis mode. Mine is very slow reading the ecm. It is usually a few seconds behind.
What proceedure are you using at diacom start up?
I start with cd diacom-p
then DIACOM-P comes on screen
then I type gmecm /f (there is a space after gmecm)
Then I'm good to go...
Old Jul 3, 2003 | 12:32 AM
ciscokid's Avatar
ciscokid
I have an 88 and I use the Diacom software and I hook right up. If you bought the package for around $300.00 it will come with 2 cables. One for 82 and up GM products and a cable specifically for TPI. If you need more info email me and I will give you my cell number and I can give you the specifics if you want. Are you entering the right VIN number for your car?
Old Jul 3, 2003 | 09:25 AM
Chatman's Avatar
Chatman
Thanks, Ciscokid. Yes, I have both and have tried both. (The software said that that some applications required the 82 and up connector in diagnostic mode.) I will send emails and phone numbers IM. Turns out that I'm only about 10 miles from you. Small Vette World.
To Diacom with 1988 TPI
