Stop Light replacement procedure 1985
Old Jul 4, 2003 | 11:24 PM
qcman007's Avatar
qcman007
Default Stop Light replacement procedure 1985
I just purchased a '85 and am bringing her out of the closet. I've read the book on how to replace the taillights ( both inboard & outboard) but find it impossible. That doesn't look to be enough space for my hand. Any body got a SHRINK RAY ?? I've only got one ( outboard) that needs replacing. Any help is appreciated. Thx :confused:
Old Jul 4, 2003 | 11:29 PM
Rich B.'s Avatar
Rich B.
Default Re: Stop Light replacement procedure 1985 (qcman007)
I've read the book on how to replace the taillights but find it impossible.
I managed to replace my outboard taillight by driving the car onto two stacked 2x6's, then lying on my back with my arm stuck up near the wheelwell opening. Which arm depends on which taillight.
Trying to change it on a lift *was* impossible. It was the lying down with my arm at an angle that did the trick.
...That, and removing the plastic inner wheelwell... :D
Old Jul 5, 2003 | 07:21 PM
MtlSphere's Avatar
MtlSphere
Outboard tail light bulb replacement...all I can say is...
YOU GOTTA BE KIDDIN ME! :banghead:
My arm looked like I stuck it into a lion cage, and the lion was hungry, when I got done!
Old Jul 5, 2003 | 10:23 PM
torqueman2002's Avatar
torqueman2002
Default Re: Stop Light replacement procedure 1985 (MtlSphere)
:iagree:
That is a job I've dreaded!
That is until this weekend when I received an ebay item: "The 1984 Corvette" manual. It is a dealership technician pre-launch technical features manual.
Having owned my Bronze 84 since new, there were very few items I had not discovered already - except on page 13.
There is a tip: it says to remove the back licence plate and reach through for the backup light replacement and also to get the inner tail lamp bulb out by removing the lense from behind. Then you can reach through the opening for the inner tail lamp and reach the outer lamp and lense.
I havent tried it, but it's worth a try. Maybe you can save a pint of blood and a pound of flesh in the process!
Good luck!
:lol: :lol:
[Modified by torqueman2002, 3:24 AM 7/6/2003]
Old Jul 5, 2003 | 11:14 PM
Rich B.'s Avatar
Rich B.
Default Re: Stop Light replacement procedure 1985 (torqueman2002)
I have tried it. If you're Billy Barty, it might work. If you're 71" and 190#, it don't... :skep:
Old Jul 6, 2003 | 11:34 AM
BIG JIM 54's Avatar
BIG JIM 54
The first one I had to replace I borowed a small friend and his hand got up in there without probs and he changed the bulb for me. The second time I had to do it myself and it was a *****. I'm 6'3", 260 (hense the name BIG JIM) and my huge ham-hocks were skinned up for a few days but I got the job done. I think I removed some bracket or brace first though. Can't remember.
Best bet? Get a 12 year-old Corvette admirer to do it for you. He'll want to change all your bulbs and wash the car too just to be near the car. Ok, that was me when I was young. But hey, there has to be more than one.
BIG JIM
Old Jul 6, 2003 | 04:44 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: Stop Light replacement procedure 1985 (BIG JIM 54)
:iagree: With Big Jim.....still have scars on my arms....but they all work :jester
Old Jul 6, 2003 | 05:26 PM
Rich B.'s Avatar
Rich B.
...I'm looking for an 18 year old...girl... :thumbs:
Old Jul 6, 2003 | 08:43 PM
MrRenoman's Avatar
MrRenoman
I've got large forearms too. As mentioned, remove the license plate but also remove the 2 other screws that are holding the bumper cover to the body. They're just under and I believe along the bottom edge of the license plate opening. This gives the bumper more room to flex which will allow you to reach in to unscrew the 2 10mm screws holding the inner lamp. Once the inner lamp is removed you can reach into the inner lamp hole and reach behind the outer lamp and unscrew the screws holding it it. There's also a couple of screws holding the bottom edge of the bumper to the body. Removing them should allow the bumper to flex enough even for large forearms. Just don't drop the wrench when unscrewing the screws. I've already lost a nice 10mm socket down there. If at all possible "don't drop the socket or wrench down there". You may never find it again. :)
Old Jul 9, 2003 | 01:32 AM
MtlSphere's Avatar
MtlSphere
Default Re: Stop Light replacement procedure 1985 (MrRenoman)
I agree with finding a small person to get the job done. And was surprised when he offered to wash the car too! I made the kid a glass of lemonade and took it to him with my wax and towels...car looks great! :cool:
To Stop Light replacement procedure 1985
