need quick 4 +3 help
Old Jul 7, 2003 | 11:22 AM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default need quick 4 +3 help
just drove an 85 with 58k.........4 + 3 tranny OD engages fine but when the OD is not engaged there is whine that increases w/ speed......goes away when you engage OD........is this normal???
Old Jul 7, 2003 | 12:29 PM
86VetteBill's Avatar
86VetteBill
Default Re: need quick 4 +3 help (My 95)
This probably isn't going to help, but my '86 4+3 does NOT do that. I wouldn't think there was a change in the 4+3 between these years??
Old Jul 7, 2003 | 12:41 PM
FlyboyZR1's Avatar
FlyboyZR1
There is a whine when the OD is NOT engaged? I'd have to say that's not normal, as mine doesn't do that either.
Old Jul 7, 2003 | 12:56 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: need quick 4 +3 help (FlyboyZR1)
I recall reading about a whine only when the OD is off. I'll have to look it up, but I do remember that it wasn't normal and was an indication of somethinig wrong.
Old Jul 8, 2003 | 08:18 AM
trupp's Avatar
trupp
This symtom is a sign that the carrier bearing in the OD section is going out. Mine has this problem. I am nursing this along until I can replace the transmission.
Old Jul 8, 2003 | 08:21 AM
LD85's Avatar
LD85
Default Re: need quick 4 +3 help (trupp)
Mine does not whine.
To need quick 4 +3 help
