LT4 P/N
Old Jul 9, 2003 | 09:45 AM
FD2BLK's Avatar
FD2BLK
Default LT4 P/N
help I bought a set of rockers that where suposed to be the roller rockers that came with the LT4 hot cam kit that fit the 3/8 studs but I am prety sure they are a set from a LT4 with the 10mm studs because they fit very loose on the 3/8 studs :mad. The numbers on the rocker are CR 01 96. I looked on line and the numbers on the rockers from the hot cam kit are CR 19 96 P/N 12370839. Can any one confirm what rockers I have? This realy burns me the LT4 studs and lock nuts are over $140 I could have bought a new set cheaper than this is going to end up.
[Modified by ejfagala, 8:46 AM 7/9/2003]
Old Jul 9, 2003 | 07:12 PM
FD2BLK's Avatar
FD2BLK
Default Re: LT4 P/N (ejfagala)
Any one with LT4 heads?
Old Jul 9, 2003 | 07:42 PM
No Go's Avatar
No Go
You might look for some 10 mm used studs and nuts...surprised they didn't come with as not much use to anyone.
Bummer...
Old Jul 9, 2003 | 09:43 PM
96GS#007's Avatar
96GS#007
I may be able to help. $140? Make me a decent offer and I'll sell you mine.
JVMason@juno.com
To LT4 P/N
