O2 sensor mounting?
Old Jul 9, 2003 | 08:15 PM
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
Default O2 sensor mounting?
I 'm ready to install super comp hooker headers on my 89 (1 3/4" no air injection fittings) and was wondering where was the best place to mount my A/F ratio O2. The headers came with one sensor mount on, I believe, the # 7 or 5 cylinder .I'm not sure if this is the optimal spot for the A/F O2 and I kinda regret not welding other fittings before I had them coated. Anyway what's the best spot? :confused:
Old Jul 15, 2003 | 03:34 PM
krivera's Avatar
krivera
Default Re: O2 sensor mounting? (JUAN J SANCHEZ)
i would say right when they all come together!
Old Jul 16, 2003 | 12:27 PM
vvv90's Avatar
vvv90
Are these just the stock O2 sensors you're talking about? Or an aftermarket 3 wires O2 sensor for your gauge???
1.) I've heard the best place is in the leanest cylinder.
2.) If it's a 5 wire wide band O2 sensor then I've seen them in the collector.
I'm no expert though.
Old Jul 16, 2003 | 09:50 PM
JUAN J SANCHEZ
Default Re: O2 sensor mounting? (vvv90)
It's for my 5-wire tuning O2 sensor . I made the mistake of sending my headers to get coated before I welded extra O2 nuts in the collectors and possibly in all the cylinders. I'm considering selling my 1 3/4" super comp Hookers (new in the box) and purchasing another set and welding on the O2 fittings. It would have to be a quick turn around because I'm ready to install my engine . Anyway, I'd like to know what the leanest cylinders usually are on a small block or at least get an idea, I know this is probably not possible without actually checking a running motor. :confused:
Old Jul 16, 2003 | 10:56 PM
vvv90's Avatar
vvv90
I asked the same question when about installing my EGT and was told the leanest cylinders are usually the back ones. 1 or 8. As for your Wide band 02, I've only seen them in the collector. Even though you got your coated, you won't be able to see the sensor in the collector under the car. Or am I confused? :confused:
I don't see any reason for ever putting a bung in every cylinder. Unless you're going to run 8 wide band 02 sensors :crazy: :crazy: That would be cool though :thumbs:
Old Jul 17, 2003 | 09:26 AM
JUAN J SANCHEZ
If welding a O2 nut in my collectors wouldn't cause the coating to chip away or have any other negative affect I will weld right over it. I haven't had time to look into it but I will. The reason for the extra O2 nuts is because once I get the A/F right with the sensor in the collector I can go back and switch positions and check what cylinders are actually richer or leaner. Perhaps I'll switch to a sequential box and the extra O2 nuts will help me tune easier. Just trying to learn as much as possible. I'm not too concerned with what the headers look like, mostly just trying not to screw up $300 worth of coating.
Old Jul 17, 2003 | 10:01 AM
vvv90's Avatar
vvv90
I would contact Jet-Hot and ask them. I don't see a problem though with just tig welding some nuts on.
I would be great for sequential though I'm not sure how it would affect the dynamics of live WOT tuning the the DFI/FAST box will do when you have the O2 permanently mounted. It might be good for trouble shooting purposes.
The ultimate setup would be a Sequential system that could read 8 wideO2's :D :thumbs:
Old Jul 19, 2003 | 12:13 AM
reallycoolcorvette's Avatar
reallycoolcorvette
just plug the hole in the #7 header with a old o2 or such and get some stainless steel header collectors with a built in o2 bung.
problem solved.
you can get em from Jegs, Summit, etc. that have the 3 bolt flange to match the hooker.
I run hookers too and have stainless steel header collectors with my o2 there. Mine are 3" to 3"
Problem solved.
:party:
Old Jul 19, 2003 | 12:19 AM
reallycoolcorvette
Default Re: O2 sensor mounting? (reallycoolcorvette)
http://www.jegs.com/cgi-bin/ncommerc...50&prmenbr=361
the pic does not show the o2 fitting but it is there. they come in different sizes too.
:chevy
*EDIT*
I do use soft aluminun gaskets and red high temp rtv for a air tight seal w/o any air leaks. This is essential since the o2 is located after the flange/mating of the two.
[Modified by reallycoolcorvette, 12:21 AM 7/19/2003]
Old Jul 19, 2003 | 07:49 PM
JUAN J SANCHEZ
Sounds like a good idea. Thanks. :iagree:
Old Jul 21, 2003 | 02:48 PM
black bart's Avatar
black bart
Put the sensor in the collector 3 inches behind where the four pipes end.
Old Jul 21, 2003 | 08:01 PM
JUAN J SANCHEZ
Default Re: O2 sensor mounting? (black bart)
sounds like another good tip will do. :thumbs:
Old Jul 21, 2003 | 08:40 PM
black bart's Avatar
black bart
:chevy
*EDIT*
:chevy
*EDIT*
RTV will ruin the O2 sensor before you do this you need to do some research on O2 installation
Be sure the rtv you buy is O2 sensor safe. If you use the wrong kind and put it on a valve cover gasket the silicone fumes will be drawin through the pcv into the intake and ruin the O2 sensor gotta be careful about what kind you use. :yesnod:
[Modified by black bart, 8:58 PM 7/21/2003]
Old Jul 21, 2003 | 10:32 PM
reallycoolcorvette
yep, all rtv is not o2 sensor safe!
Old Jul 27, 2003 | 12:01 PM
DiabolicalDave's Avatar
DiabolicalDave
Dude,
I just did this. Here are some pic's:
To O2 sensor mounting?
