Rear blown again
Oh and thanks for the help pushing the car off the line, down the return road, around past the ticket booth..... I really apriciate the help!!!! :cheers:
[Modified by RichS, 11:00 PM 7/12/2003]
I blew the spiders apart but the rest of the rear is ok. I had a spare set from my last blown rear so I rebuilt it with those. I may buy a posi rebuild kit and have the new spiders from the kit cryro'd for added strength.
If your interested, I can tell you the biggest reason for spider gear failure: It's posi clutch wear!
How? Well, I'll explain:
-The spider gears to spline gear tooth engagement, like any gear set, will try to climb apart when torgue is applied. If you notice, this movement puts pressure on the clutch pack to cause it to lock the axles to the carrier.
Now, since this is by design the spreading of the gears is what locks the clutchpacks, it can be a bad thing if the gears are allowed to spread too far apart under torque...so clutch pack thickness is critical! Too loose a clutch pack will allow the spider/axle gears to spread to the point of almost no tooth mesh and under high torque loading...snap, spider gear is history. :(
So, in otherwords, if you did not replace the clutch packs and set the proper preload after spider gear failure, you set yourself up for a repeat of the first failure.
My advice: Rebuild the carrier with new spiders and make sure you know how to properly setup clutchpack thickness/preload and the rear should last a long time. There are a lot of D44's that live with 600+ HP with no problems ever...so it's not the GM design that did you in, it's wear.
