Unidentified plug...
Old Jul 13, 2003 | 06:42 PM
AEmedic's Avatar
AEmedic
Default Unidentified plug...
In the left front below the headlight where the side maker light and the cornering light there is a two wire plug (red wire and orange wire) that has no where to plug into... I am really hoping someone will be able to help me identify where it plugs into :confused: .
Thanks in advance!
Old Jul 13, 2003 | 06:45 PM
LaVidaLoca's Avatar
LaVidaLoca
Default Re: Unidentified plug... (AEmedic)
Hmmm. Purge canister solenoid maybe?
Post a picuture. That might help.
Old Jul 13, 2003 | 06:58 PM
AEmedic's Avatar
AEmedic
Default Re: Unidentified plug... (LaVidaLoca)
[Modified by AEmedic, 4:06 PM 7/13/2003]
Old Jul 13, 2003 | 07:23 PM
STL94LT1's Avatar
STL94LT1
It looks like the hood lights plug.
Old Jul 13, 2003 | 08:31 PM
AEmedic's Avatar
AEmedic
Default Re: Unidentified plug... (STL94LT1)
This is a better view of the plug...
The plug above the unidentified plug in this picture is the hood light plug...
Old Jul 13, 2003 | 09:01 PM
tkrussell's Avatar
tkrussell
That's the plug to the fuse for the engine compartment lamps. The fuse is located at the rear of the side marker lamp housing. It is black, about the size of a zippo lighter. (on my 95)
Old Jul 13, 2003 | 10:24 PM
STL94LT1's Avatar
STL94LT1
From looking at your pictures, it looks like the fuse/connection for that plug is missing.
Old Jul 13, 2003 | 10:27 PM
kittmaster's Avatar
kittmaster
It IS the fuse holder for the engine lamps. You'll find the cap for it mounted to the car somewhere in that area. I'd put the fuse back in and reconnect it to its mounting cap to protect the connector from the elements
Old Jul 13, 2003 | 11:10 PM
AEmedic's Avatar
AEmedic
Default Re: Unidentified plug... (tkrussell)
Okay, cool... Now at least I know what it is supposed to plug into. Only one problem, there is no fuse I guess it's off to the dealer to get one at least it makes since now why the underhood lights do not work!
Thank you guys for the help!
Chris
To Unidentified plug...
